PyPortal and MQTT help needed - network problem?
prcutler
Post by prcutler »
I have two CircuitPython programs for my PyPortal, that I've adapted from Learn guides. Both programs both work individually, but not when I combine them. The first connects and subscribes to a MQTT broker and a topic. The second uses the PyPortal() class to fetch an image, have it converted by Adafruit IO, and display on the PyPortal.
I think the error is related to the PyPortal's networking and socket - MQTT has the socket in use, and blocks pyportal.fetch() from using the network. Or at least that's my best guess.
The code is below, and on line 90 I have
MQTT.set_socket(socket, pyportal.network._wifi.esp)
and then pyportal.fetch is called when a message is received resulting in the following error. If anyone has any suggestions, please let me know and thanks in advance.
--Paul
Auto-reload is on. Simply save files over USB to run them or enter REPL to disable.
code.py output:
Connecting to WiFi...
Connecting to AP Dispatch
Connected!
Subscribing to albumart
New message on topic albumart: Ping!
Retrieving data...Traceback (most recent call last):
  File "code.py", line 117, in <module>
  File "adafruit_minimqtt/adafruit_minimqtt.py", line 805, in loop
  File "adafruit_minimqtt/adafruit_minimqtt.py", line 860, in _wait_for_msg
  File "adafruit_minimqtt/adafruit_minimqtt.py", line 411, in _handle_on_message
  File "code.py", line 58, in message
  File "adafruit_pyportal/__init__.py", line 307, in fetch
  File "adafruit_portalbase/network.py", line 478, in fetch
  File "adafruit_requests.py", line 864, in get
  File "adafruit_requests.py", line 710, in request
  File "adafruit_requests.py", line 563, in _get_socket
RuntimeError: Sending request failed
And here's the code:
# SPDX-FileCopyrightText: 2021 ladyada for Adafruit Industries
import time
import board
import adafruit_esp32spi.adafruit_esp32spi_socket as socket
import adafruit_pyportal
import adafruit_minimqtt.adafruit_minimqtt as MQTT
from adafruit_pyportal import PyPortal
### WiFi ###
# Get wifi details and more from a secrets.py file
try:
    from secrets import secrets
except ImportError:
    print("WiFi secrets are kept in secrets.py, please add them there!")
    raise
# ------------- MQTT Topic Setup ------------- #
mqtt_topic = "albumart"
### Code ###
# Define callback methods which are called when events occur
# pylint: disable=unused-argument, redefined-outer-name
def connected(client, userdata, flags, rc):
    # This function will be called when the client is connected
    # successfully to the broker.
    print("Subscribing to %s" % (mqtt_topic))
    client.subscribe(mqtt_topic)
def disconnected(client, userdata, rc):
    # This method is called when the client is disconnected
    print("Disconnected from MQTT Broker!")
def message(client, topic, message):
    """Method callled when a client's subscribed feed has a new
    value.
    :param str topic: The topic of the feed with a new value.
    :param str message: The new value
    if message == "Ping!":
        print("New message on topic {0}: {1}".format(topic, message))
        #try:
        response = pyportal.fetch()
        print("Response is", response)
        #except RuntimeError as e:
        #    print("Some error occurred, retrying! -", e)
# Setup the PyPortal
# Set up where we'll be fetching data from
DATA_SOURCE = "https://silversaucer.com/album/data"
response = None
# There's a few different places we look for data in the photo of the day
image_location = ["image_url"]
artist = ["artist"]
album = ["album"]
# the current working directory (where this file is)
cwd = ("/"+__file__).rsplit('/', 1)[0]
pyportal = PyPortal(url=DATA_SOURCE,
                    json_path=(artist, album),
                    status_neopixel=board.NEOPIXEL,
                    default_bg=cwd+"/nasa_background.bmp",
                    text_font=cwd+"/fonts/Arial-12.bdf",
                    text_position=((85, 260), (85, 280)),
                    text_color=(0xFFFFFF, 0xFFFFFF),
                    text_maxlen=(50, 50), # cut off characters
                    image_json_path=image_location,
                    image_resize=(320, 320),
                    image_position=(80, 0))
# Connect to WiFi
print("Connecting to WiFi...")
pyportal.network.connect()
print("Connected!")
# Initialize MQTT interface with the esp interface
# pylint: disable=protected-access
# Set up a MiniMQTT Client
mqtt_client = MQTT.MQTT(
    broker=secrets["broker"],
    username=secrets["user"],
    password=secrets["pass"],
    is_ssl=False,
# Setup the callback methods above
mqtt_client.on_connect = connected
mqtt_client.on_disconnect = disconnected
mqtt_client.on_message = message
# Connect the client to the MQTT broker.
mqtt_client.connect()
while True:
# Poll the message queue
    mqtt_client.loop()
    time.sleep(1)
