SPI conflict?
michaelmcs
SPI conflict?
Post by michaelmcs »
setup:
Adafruit CircuitPython 7.2.5 on 2022-04-06; FeatherS2 with ESP32S2
I2C/SPI LCD backpack
PT 1000 amplifier
import gc
import sys
import time
import board
import digitalio
import busio
import adafruit_max31865
import adafruit_character_lcd.character_lcd_spi as character_lcd
def display(string):
        lcd.clear()
        lcd.message = string
lcd_columns = 20
lcd_rows = 5
spi = busio.SPI(board.SCK, MOSI=board.MOSI)
latch = digitalio.DigitalInOut(board.D5)
lcd = character_lcd.Character_LCD_SPI(spi, latch, lcd_columns,
                                    lcd_rows)
spi = busio.SPI(board.SCK, MOSI=board.MOSI,MISO=board.MISO)
cs = digitalio.DigitalInOut(board.D9)
adafruit_max31865.MAX31865(spi, cs, wires=3,
                rtd_nominal=1000.0, ref_resistor=4300.0)
lcd.backlight = True
lcd.clear()
def temp():
    try:
        t= temperature * 9 / 5 + 32
        return(int(t))
    except:
        return(0)
currentTemp = 22
setTemp = 55
while True:
    previousTemp = currentTemp
    currentTemp = sensor1.temp()
    currentTemp = 55
    display("%d / %d" % (round(currentTemp), round(setTemp)))
    time.sleep(5)
    setTemp += 1
when I run this code I get the following output:
code.py output:
File "code.py", line 20, in <module>
ValueError: IO36 in use
If I have only the LCD or only the PT1000 in the code, it runs. If I have both, no mater the order, whichever comes second throws the error.
What am I doing wrong?
tannewt
Re: SPI conflict?
Post by tannewt »
Only do `spi = busio.SPI(board.SCK, MOSI=board.MOSI,MISO=board.MISO)` once and use the spi object for both libraries.
dastels
Re: SPI conflict?
Post by dastels »
Better, if you have board.SPI() just use that rather than busio.SPI(). It caches the instance and uses the appropriate pins.
michaelmcs
Re: SPI conflict?
Thank-you both. I've got both the lcd display and PT1000 running ... sort of.
I can display to the lcd but following a read of the PT1000, the display just shows garbage. However, the temperature is still being read and is reasonable (I write it to REPL)
I had assumed that the library functions would handle the lock/unlock of the SPI bus. Maybe that was expecting too much?
Suggestions are appreciated.
I put the sleeps in the code so that I would have time to read the display.
import gc
import sys
import time
import board
import digitalio
import busio
spi = board.SPI()
sensor = adafruit_max31865.MAX31865(spi, cs, wires=3, rtd_nominal=1000.0, ref_resistor=4300.0)
def readTemp():
    try:
        t= sensor.temperature * 9 / 5 + 32
        time.sleep(2)
        return(int(t))
    except:
        return(0)
lcd_columns = 20
lcd_rows = 4
lcd = character_lcd.Character_LCD_SPI(spi, latch, lcd_columns, lcd_rows)
    lcd.clear()
    time.sleep(2)
debugMessage = '''Debug check
  Check  %d
  Filler Text
  Temperature now %d'''
display(debugMessage % (0, 0.0))
time.sleep(5)
count = 1
while count:
    setTemp =  readTemp()
    print('loop %d: currentTemp == %d' % (count, setTemp))
    display(debugMessage % (count, setTemp))
    count += 1
