I have 2 Adafruit QT Py ESP32-C3, part # 5405.
I attempted to add CircuitPython to these devices following these directions take from this web page:
https://learn.adafruit.com/adafruit-qt- ... cuitpython
I did this:
Plug your board into your computer, using a known-good data-sync cable, directly, or via an adapter if needed.
Click the reset button once (highlighted in red above), and then click it again when you see the RGB status LED(s) (highlighted in green above) turn purple (approximately half a second later). Sometimes it helps to think of it as a "slow double-click" of the reset button.
Once successful, you will see the RGB status LED(s) turn green (highlighted in green above). If you see red, try another port, or if you're using an adapter or hub, try without the hub, or different adapter or hub.
If double-clicking doesn't work the first time, try again. Sometimes it can take a few tries to get the rhythm right!
You will see a new disk drive appear called QTPYS2BOOT.
I tried several times and was never able to get the
QTPYS2BOOT drive to appear.
I then tried doing the Factory Reset and Bootloader Repair per this page:
https://learn.adafruit.com/adafruit-qt- ... -3107941-7
I was able to open the ESP Web Flasher using the Chrome browser and erase the flash memory:
Connected successfully.
Try hard reset.
Chip type ESP32-C3
Connected to ESP32-C3
MAC Address: 10:91:A8:32:8E:64
Uploading stub...
Running stub...
Stub is now running...
Detecting Flash Size
FlashId: 0x164020
Flash Manufacturer: 20
Flash Device: 4016
Auto-detected Flash size: 4MB
Erasing flash memory. Please wait...
Finished. Took 16666ms to erase.
Then I programmed the QT Py ESP32-S2 with this result:
Image header, Magic=0xFF, FlashMode=0xFF, FlashSizeFreq=0xFF
Writing data with filesize: 3082336
Erase size 3082336, blocks 189, block size 0x4000, offset 0x0000, encrypted no
Took 35023ms to write 3082336 bytes
Erase size 0, blocks 0, block size 0x4000, offset 0x0000, encrypted no
To run the new firmware, please reset your device.
I then tried to reset the QT Py ESP32-S2 and followed these directions:
Reset the board
Now that you've reprogrammed the board, you need to reset it to continue. Click the reset button to launch the new firmware.
The NeoPixel LED on the QT Py ESP32-S2 will light up in a rainbow swirl.
You've successfully returned your board to a factory reset state!
The reset did not work.
Has Adafruit had some problems with these boards?
I really like this board and how it’s working with on a previous QT Py ESP32-S2 and that is why I purchased 2 more boards.
I am over the 30 day return time so I can’t return the boards.
These 2 boards were purchased on April 6th under Order #2820258-4036924415.
So, what do you suggest I do?
Tom Henry
Problem adding CircuitPython to QT PY ESP32-C3 [was S2]
- Tom_Henry
- TI545
Re: Problem adding CircuitPython to QT PY ESP32-S2
Which board do you have? Your title reads “s2” but part 5405 is a “c3” chip.
I have a few esp32-s2 qtpy and haven’t had trouble with them.
- Tom_Henry
Thanks for the correction. My problem is with the C3 not S2.
Tom Henry
Tom Henry
- danhalbert
The C3 does not have native USB; it only has a serial USB connection. So you can't see the BOOT drive. We are working on CircuitPython for this board, but it's early. The guide is here: https://learn.adafruit.com/adafruit-qt- ... -dev-board. CircuitPython is not mentioned in that guide yet because it's still experimental.
If you want an ESP board with CircuitPython, we recommend the ESP32-S2 boards for now.
- Tom_Henry
Now I know what I did. I ordered the wrong part. I meant to order 2 of the QT Py ESP32-S2 not C3.
I guess I will just save those for a later time when you have CircuitPython working on them.
I just went outside to one my sensors running on the QT Py ESP32-S2 and the AHT20 and PCF8523. I based it on a Ruiz Brother projects with the 3D printed case: https://learn.adafruit.com/qt-py-snap-fit-case
Thanks for making me aware of the C3.
Tom Henry
Tom Henry
