I just received two(2) QT Py RP2040 a few day ago. I update the Python 7.2.5. I download the BME_680 bundle and copied the library file and code.py to the QT PY RP2040. I continuously get this error:
soft reboot
code.py output:
File "code.py", line 9, in <module>
RuntimeError: No pull up found on SDA or SCL; check your wiring
Code done running.
This occurs on both QT Py RP2040s. I tried different combination of BME-688 sensors and Stemma connectors. I tried installing a older version on python 7.2.4. & 7.3.0.rc2. Error remains.
Please help. TY
Alex J.
- AJJ1
- neradoc
Re: RuntimeError: No pull up found on SDA or SCL; check your
Hi, I don't know your code, but the QT PY RP2040 has the stemma QT connector wired to SDA1 and SCL1 or board.STEMMA_I2C().
If you are using code that uses board.I2C() or busio.I2C(board.SCL, board.SDA) you need to update it with those.
- AJJ1
neradoc,
Thank you. Here's the original code:
I changed the I2C method to "board.STEMMA_I2C()" and it works. Question: How would I write the code for "board.I2C()"? i2c = board.I2C(SCL1, SDA1)?
V/r
Alex J
# SPDX-FileCopyrightText: 2021 ladyada for Adafruit Industries
import time
import board
import adafruit_bme680
# Create sensor object, communicating over the board's default I2C bus
i2c = board.STEMMA_I2C() # uses board.SCL and board.SDA
bme680 = adafruit_bme680.Adafruit_BME680_I2C(i2c, debug=False)
# change this to match the location's pressure (hPa) at sea level
bme680.sea_level_pressure = 1013.25
# You will usually have to add an offset to account for the temperature of
# the sensor. This is usually around 5 degrees but varies by use. Use a
# separate temperature sensor to calibrate this one.
temperature_offset = -5
while True:
print("\nTemperature: %0.1f C" % (bme680.temperature + temperature_offset))
print("Gas: %d ohm" % bme680.gas)
print("Humidity: %0.1f %%" % bme680.relative_humidity)
print("Pressure: %0.3f hPa" % bme680.pressure)
print("Altitude = %0.2f meters" % bme680.altitude)
time.sleep(1)
V/r
Alex J
- danhalbert
i2c = busio.I2C(board.SCL1, board.SDA1) would be for the STEMMA connector on this board.Question: How would I write the code for "board.I2C()"? i2c = board.I2C(SCL1, SDA1)?
board.I2C() on this board are the SCL/SDA pins. But on other boards, the STEMMA pins may be the same as the SCL/SDA pins. It depends on whether there were spare pins available or not.
