This is CircuitPython 7.3.0, the latest minor revision of CircuitPython, and is a new stable release.
Notable changes to 7.3.0 since 7.2.5
- Experimental mDNS support.
- USB to to Serial/JTAG support for REPL on appropriate boards.
- Initial experimental USB host support.
- Merge MicroPython 1.18 changes.
- Preliminary zlib module support. gzip module will be added later.
- RP2040 PIO: Background write to a PIO state machine. Looping is possible.
- RP2040 PIO: wrap and wrap_target support.
- keypad: scan keystates immediately on creation.
- Improve NeoPixel timings on many ports, to handle a wider range of devices.
- Add floppyio, used in conjunction with a library.
- Allow TileGrid bitmap to be changed.
- Module support matrix includes frozen modules for each board.
- f-strings available in all builds.
Firmware downloads are available from the downloads page on circuitpython.org. The site makes it easy to select the correct file and language for your board.
Installation
To install follow the instructions in the Welcome to CircuitPython! guide. To install the latest libraries, see this page in that guide.
Try the latest version of the Mu editor for creating and editing your CircuitPython programs and for easy access to the CircuitPython serial connection (the REPL).
Documentation
Documentation is available in readthedocs.io.
Port status
CircuitPython has a number of "ports" that are the core implementations for different microcontroller families. Stability varies on a per-port basis. As of this release, these ports are consider stable:
- atmel-samd: Microchip SAMD21, SAMx5x
- cxd56: Sony Spresense
- espressif: Espressif ESP32-S2
- nrf: Nordic nRF52840, nRF52833
- raspberrypi: Raspberry Pi RP2040
- stm: ST STM32F4 chip family
- broadcom: Raspberry Pi boards such as RPi 4, RPi Zero 2W
- espressif: ESP32-S3, ESP32-C3
- litex: fomu
- mimxrt10xx: NXP i.MX RT10xxx
- stm: ST non-STM32F4 chip families
This release is a relabeling of 7.3.0-rc.2 and is otherwise the same as that release.
Known issues
- See https://github.com/adafruit/circuitpython/issues for other issues, including issues still to be addressed for:
Thank you to all who used, tested, and contributed since 7.2.5, including the contributors above, and many others on GitHub and Discord. Join us on the Discord chat to collaborate.
