Here is the server (Raspberry pi 3B+) python code: https://github.com/InventerBots/Green-h ... /server.py
import math
import socket
HOST = '0.0.0.0' # server IP
PORT = 10004
RELAY_ON=bytes(1)
RELAY_OFF=bytes(0)
tempRaw=0
with socket.socket(socket.AF_INET, socket.SOCK_STREAM) as s:
s.bind((HOST, PORT))
s.listen()
conn, addr = s.accept()
with conn:
print('Connected by', addr)
while True:
#--- temperature calculations ---#
# tempK=1/((1/298.15)+(1/3977)*math.log((10000/(1023/int(conn.recv(1023))-1))/10000))
# tempF=(tempK-273.15)*(9/5)+32
# print("Receved: ", tempF)
data=int(conn.recv(1023))
x=0
if data < 10:
x=data
#print(x)
tempRaw[x]=data
print("sensor: ",x)
print(tempRaw[x])
#--- fan control ---#
# if tempF>80 :
# conn.send(RELAY_ON)
# print("on")
# else :
# conn.send(RELAY_OFF)
# print("off")
The project uses an Adafruit feather Ethernet add-on board and a feather M4 express running the latest firmware, and a network switch connecting everything together with Ethernet.
I do have the project somewhat working on an Arduino uno, but I ran into some architecture issues.
https://github.com/InventerBots/Green-h ... Client.ino
Any help or constrictive criticism will be appreciated.
