I bought a cheap unpowered Anker USB hub recently and initial tests with three Circuit Playground Expresses/Bluefruits are not promising. I seem to only get one serial console and one CIRCUITPY drive showing up. A pair of cheap USB power meters tell me that the voltage and current (110mA, got some NeoPixels on) are reasonable. My monitor has a two port hub in it and the devices work ok in that.
Is there a particular hub feature that CircuitPython requires?
USB hubs vs CircuitPython
- mikeysklar
Re: USB hubs vs CircuitPython
Interesting finding.
Is the Anker USB hub you are using a USB v2 or v3?
I've had the best success with USB 2.0 powered hubs.
https://www.adafruit.com/product/961
Does it make any difference if you plug a lipo into the CPX Bluefruit while using the hub?
Do you have issues programming or bringing up a serial console when using Arduino code?
- kevinjwalters
It's a USB 3.0 hub. My desktop has a mix of ports and the Anker hub does seem to be viable if I plug it into a USB 2.0 host port and plug the CPX/CPB's in sequentially with a slight pause between each one.
My montiors are antiques and will be USB 2.0. I've ordered some cheap, no-brand USB 2.0 hubs and will do some more experimentation when they arrive, thanks.
- danhalbert
I had trouble with an inexpensive "Amazon Basics" 3.1 hub (USB-C). I have had much better luck with the aluminum-cased multi-function USB-C hubs that also have HDMI, Ethernet, etc. These are often advertised as port expanders for Macs (but I am using Linux).
- kevinjwalters
I got a cheap (sub 5 USD) one advertised as USB 2.0 and this seems to have done the trick even when used in a USB 3.0 A port . I plugged them in sequentially and I've got 4 CIRCUITPY drives and 4 COM ports. I'm keeping the power around the 110mA level per board (green pixels full on) as I imagine something bad will happen if I go much above that on this humble, unpowered hub.
- Attachments
- Low brand USB2.0 hub which seems ok for CircuitPython
- cheapo-usb2-hub-ok-circuitpython.jpg (7.3 KiB) Viewed 114 times
- mikeysklar
Is the takeaway that reliable CircuitPython drive mounting and REPL console can currently be achieved via USB 2.0, but not so much with USB 3.x?
- danhalbert
I would not say that. I use a USB-C port adapter that has 3 USB 3 "A" ports for all my CircuitPython debugging, and it's fine. It was the cheap USB 3.1 hub that had trouble.mikeysklar wrote:Is the takeaway that reliable CircuitPython drive mounting and REPL console can currently be achieved via USB 2.0, but not so much with USB 3.x?
- kevinjwalters
The picture I posted before is a bit misleading with the blue plastic on the four USB ports. My one looks like this one.
I'll try both hubs with my laptop at some point.
