When i rotate the sensor on X/Y i get numbers that don't make sense. Right now a full rotation gives me seemingly random values between 100 and 120 degrees.
Simple python but i'm missing something here, any help would be appreciated
import time
from math import atan2, degrees
import board
import adafruit_lis3mdl
i2c = board.I2C() # uses board.SCL and board.SDA
sensor = adafruit_lis3mdl.LIS3MDL(i2c)
def vector_2_degrees(x, y):
angle = degrees(atan2(y, x))
if angle < 0:
angle += 360
return angle
def get_heading(_sensor):
magnet_x, magnet_y, _ = _sensor.magnetic
return vector_2_degrees(magnet_x, magnet_y)
def run():
while True:
print("heading: {:.2f} degrees".format(get_heading(sensor)))
time.sleep(1.0)
if __name__ == '__main__':
run()
I was able to calibrate it but I also can't find a doc on how to apply these calibration numbers to the above code.
I also am getting the same results from this arduio - North is 115, East and West are both 104 etc
lis3mdl.read(); // get X Y and Z data at once
sensors_event_t event;
lis3mdl.getEvent(&event);
float heading = (atan2(event.magnetic.y, event.magnetic.x) * 180) / M_PI;
// Normalize to 0-360
if (heading < 0)
heading = 360 + heading;
Serial.println(heading);
delay(100);
Serial.println();
