SPI MISO and MOSI on same Eval Board Pin
- skcalanderson
Hello, I am attempting to use an older magnetic rotary sensor eval board that has a SPI interface. But it only has a Data Out pin and you have to send data into that pin to get back the data. I have found c++ code that switches the Microcontroller pins from output to input and back, i.e. using the same pin for SPI data, but how would I do this with Circuit Python. It appears that the bitbang library requires exclusive MISO and MOSI pins. Any guidance would be appreciated.
- neradoc
Re: SPI MISO and MOSI on same Eval Board Pin
Sorry my knowledge of SPI is not great, but busio.SPI supports half-duplex, is that what you are looking for ?
https://docs.circuitpython.org/en/lates ... #busio.SPI
It's not supported in bitbangio though.
