After connecting my rfm9x LoRa radio to a raspberry pi 3b, the OLED displays an error that the radio is not detected and I keep getting an error that says “failed to detect rfm9x with correct version—check wiring”
the code I used is the following from the Adafruit website:
# SPDX-FileCopyrightText: 2018 Brent Rubell for Adafruit Industries
Wiring Check, Pi Radio w/RFM9x
Learn Guide: https://learn.adafruit.com/lora-and-lorawan-for-raspberry-pi
Author: Brent Rubell for Adafruit Industries
import time
import busio
from digitalio import DigitalInOut, Direction, Pull
import board
# Import the SSD1306 module.
import adafruit_ssd1306
# Import the RFM9x radio module.
import adafruit_rfm9x
# Button A
btnA = DigitalInOut(board.D5)
btnA.direction = Direction.INPUT
btnA.pull = Pull.UP
# Button B
btnB = DigitalInOut(board.D6)
btnB.direction = Direction.INPUT
btnB.pull = Pull.UP
# Button C
btnC = DigitalInOut(board.D12)
btnC.direction = Direction.INPUT
btnC.pull = Pull.UP
# Create the I2C interface.
# 128x32 OLED Display
reset_pin = DigitalInOut(board.D4)
display = adafruit_ssd1306.SSD1306_I2C(128, 32, i2c, reset=reset_pin)
# Clear the display.
display.fill(0)
display.show()
width = display.width
height = display.height
# Configure RFM9x LoRa Radio
CS = DigitalInOut(board.CE1)
RESET = DigitalInOut(board.D25)
spi = busio.SPI(board.SCK, MOSI=board.MOSI, MISO=board.MISO)
while True:
# Clear the image
display.fill(0)
# Attempt to set up the RFM9x Module
try:
rfm9x = adafruit_rfm9x.RFM9x(spi, CS, RESET, 915.0)
display.text('RFM9x: Detected', 0, 0, 1)
except RuntimeError as error:
# Thrown on version mismatch
display.text('RFM9x: ERROR', 0, 0, 1)
print('RFM9x Error: ', error)
# Check buttons
if not btnA.value:
# Button A Pressed
display.text('Ada', width-85, height-7, 1)
display.show()
time.sleep(0.1)
if not btnB.value:
# Button B Pressed
display.text('Fruit', width-75, height-7, 1)
display.show()
time.sleep(0.1)
if not btnC.value:
# Button C Pressed
display.text('Radio', width-65, height-7, 1)
display.show()
time.sleep(0.1)
display.show()
time.sleep(0.1)
