Is multiprocessing supported?
Kc2021
Post by Kc2021 »
I have tested several adafruit products, they are all great quality. However they all seems to present the same problem when use with the multiprocessing module. The script dose not run and throws a Segmentation fault (core dumped). The script runs with threading but not multiprocessing.
These does not works:
import time
import board
import adafruit_bno055
import threading
import multiprocessing
fpsFilt = 0
timeStamp = 0
i2c = board.I2C()
sensor = adafruit_bno055.BNO055_I2C(i2c)
def test():
    while True:
        print("Quaternion: {}".format(sensor.quaternion))
Gps = multiprocessing.Process(target=test)
Gps.start()
But these works:
import time
import board
import threading
fpsFilt = 0
timeStamp = 0
i2c = board.I2C()
def test():
    while True:
Gps = threading.Thread(target=test)
Gps.start()
Is there any way to use an adafruit product with multiprocessing?Thanks.
Reason: Add code tags
dastels
Re: Is multiprocessing supported?
Post by dastels »
What boards are you trying these on?
blakebr
Post by blakebr »
Tracking
Kc2021
Post by Kc2021 »
I am using a PA1010D connected to a linux 18 pc with MCP2221A through the stemma qt port.
This also happens with BNO055, and Servo controller like I2C interface - PCA9685. The problem arises only when the while loop is in a multiprocessing module. I am working in a very cool project and I need to get data from several adafruit sensors at the same time without having the slower refresh rate sensors slow down the faster sensors. So I want to put every sensor loop in a different process.
Where you able to reproduce the error?
dastels
Post by dastels »
I should have been more specific: what are you running the code on?
Kc2021
Post by Kc2021 »
Thankyou for addressing my code problem. I think I don't fully understand your question. Please be patient with me, when you say "what are you running the code on?
" what do you mean?
If an example like these where to be followed and the while loop placed inside a def and converted to a process will it produce an error?
https://learn.adafruit.com/circuitpytho ... p2221/gpio
For me every code with a multiprocessing.Process produces an error.
dastels
Post by dastels »
I mean are you running it on a Raspberry Pi? a SAMD51 (aka "M4") board?
Kc2021
Post by Kc2021 »
I am using a regular pc with ubuntu 20 installed, I use the MCP2221A as an usb to ic2 interphase.
Kc2021
Post by Kc2021 »
the set up is like this but running Linux and a script.
https://www.adafruit.com/product/4471
dastels
Post by dastels »
OK. There may be some race conditions or resource contention or non-atomic ordering issues using the USB/I2C adaptor.
Can you check that access to the device is atomic? If not, you could add a wrapper with a semaphore approach to make it atomic.
Kc2021
Post by Kc2021 »
It is the first time I encounter the term "atomic". Could you give me an example of a wrapper with a semaphore approach? I am researching about is now.
gammaburst
Post by gammaburst »
By the way, after you solve the multiprocessing problem, beware the BNO055 is antisocial. It uses I2C clock-stretching to hog the bus for a couple hundred microseconds at a time, restricting your ability to talk fast to multiple devices.
Kc2021
Post by Kc2021 »
I can use another MCP2221A to handle BNO055, but I will have to find out how to use 2 MCP2221A in the same pc without problems.
Have anybody reproduce the error? It is very simple to reproduce. Just get the while loop inside the multiprocessing module.
dastels
Post by dastels »
You want to look into Mutex and it's uses. The key is that when something (i.e. a process/thread) want to use the I2C adapter it has exclusive access to it until it's done. Then something else can have it.
Kc2021
Post by Kc2021 »
Ok I will research that.
