Pins "in use" right from the start on STM32
rgbapcb
Post by rgbapcb »
When I try `digitalio.DigitalInOut(board.A10)`, I get `ValueError: A10 in use`. This happens on the BlackPill board for pins A10, A11, A12, C14, C15.
For pins C14,C15, the reason might be here: https://github.com/adafruit/circuitpyth ... gpio.c#L41
For pins A10-A12, my guess is https://github.com/adafruit/circuitpyth ... /usb.c#L85
and/or https://github.com/adafruit/circuitpyth ... gpio.c#L36
Should I try to "hack" these parts of the code as a workaround? Or are there some makefile options? Or maybe even CirctuitPython commands to deinit/release those pins?
rgbapcb
Re: Pins "in use" right from the start on STM32
Post by rgbapcb »
I got access to pins C14, C15 by commenting out https://github.com/adafruit/circuitpyth ... .c#L43-L44
Pins A11, A12 are in use by USB, I don't need them for other purposes.
But how do I prevent pin A10 from being "in use"? https://github.com/adafruit/circuitpyth ... /usb.c#L81 says that pin A10 gets occupied by USB_OTG_FS_ID. How do I prevent precisely that? Adding `#define BOARD_NO_USB_OTG_ID_SENSE (1)` to the board-specific mpconfigboard.h such as https://github.com/adafruit/circuitpyth ... figboard.h causes the device to appear as "Unknown USB Device (Device Descriptor Request Failed)" in Device Manager in Windows 10, and no REPL connection.
rgbapcb
Post by rgbapcb »
Actually, the hack allows pins C14, C15 to not throw the "in use" error anymore, but using them among the `row_pins` of `keypad.KeyMatrix()` prevents the key matrix from detecting any events, also from other pins. The condition `if key_matrix.events.get()` is never triggered. Without using pins C14 and C15, it works.
