problem using a library
Elektrix
Post by Elektrix »
Hello all,
I run CircuitPython 7.3.1 on a Feather M0 Express. I installed the adafruit_logging library from the latest release. When I import this library in the main file code.py everything is ok:
import adafruit_logging as logging
gives no error.
Then, I created a file morse.py in the lib folder and I want to import the logging library in the morse.py file. So in this file I wrote:
and I wrote
import morse
in code.py. But this gives me an errror:
code.py Ausgabe:
Zurückverfolgung (jüngste Aufforderung zuletzt):
  Datei "code.py", Zeile 4, in <module>
OSError: [Errno 5] Eingabe-/Ausgabefehler
CircuitPython runs in German as I am not a native English speaker.
The rest of the code from my morse.py runs fine. What am I doing wrong?
Thanks in advance
Elektrix
dastels
Re: problem using a library
Post by dastels »
It's likely because morse.py is in the CIRCUITPY/lib folder. Have you tried moving it to CIRCUITPY?
Elektrix
Post by Elektrix »
Thank you for your hint! I moved the morse.py file into the main folder and back to try out what you wrote and to replicate the error. When the morse.py file is in the lib folder everything works as expected. This was not the case in the beginning. In the meantime I did a full hardware reset and power disconnect to the feather and since then in works. Probably I should have done a full hardware reset after the installation of the logger library.
Thank you very much
Elektrix
dastels
Post by dastels »
Sounds like something got cached.
Elektrix
Post by Elektrix »
Finally, I found the real error. The error described above appeared again. I erased and formatted the CIRCUITPY drive using the REPL console as described in the pdf tutorial. I loaded my files and the library again. Now everything is fine. Looks like the filesystem was corrupted.
Elektrix
