adafruit_logging gives no output
Elektrix
Post by Elektrix »
Hello all,
I have a ItsyBitsy M0 Express with CircuitPython 7.3.1 and I want to use the adafruit_logging library. Now that I have a working file system I don't get errors but I also don't get any output via the serial console.
I tried the following:
I installed the adafruit_logging.mpy file from the latest bundle into the lib folder.
I copied the example from here: https://learn.adafruit.com/a-logger-for ... g-a-logger into a new empty code.py file.
The code runs. There are no errors. But there also is no output. I use a laptop with Debian and screen in the terminal window. The ItsyBitsy restarts after every file write. Everything else shows up nicely and the print command also works.
What am I doing wrong?
Elektrix
mikeysklar
Re: adafruit_logging gives no output
Post by mikeysklar »
When you run screen are you sure you are connecting to the correct device? Are you able to stop the running program via the REPL console? It should be ^C to interrupt and ^D to resume. There can be several device names that are similar depending on your distribution.
neradoc
Post by neradoc »
Hi, there seems to be a bug, or API inconsistency in adafruit_logging.getLogger, where it defaults to no handler.
Try adding a stream handler for now:
logger_test = logging.getLogger('test')
logger_test.setLevel(logging.ERROR)
logger_test.addHandler(logging.StreamHandler())
logger_test.info('Info message')
logger_test.error('Error message')
Elektrix
Post by Elektrix »
Thank you for the Info, now it works. When it is a bug where is the right place for me to write a bug report?
Elektrix
Elektrix
Post by Elektrix »
@neradoc:
I found your bug report here: https://github.com/adafruit/Adafruit_Ci ... /issues/33, together with the missing return character bug. Thanks for your work!
Elektrix
