Originally I was trying to study to see if it was possible to have multiple animations playing at once (the comet animation as a meteor shower to be specific, neopixels). But then I had a thought
Theater chase would be the optimal animation for my project if it is possible to give the neopixels in the middle/end of the Neopixels lighting up the ability to fade out rather
than the instantaneous On -> Off they usually do. How would one achieve an effect like this? I was going over the nested script for theater chase but came up empty handed. Any advice would be greatly appreciated
Animation Library question
- mikeysklar
Re: Animation Library question
Increasing the tail value for the comet animation should give you a long strip of LEDs fading out.
You might need to get to a lower level of customization for the effects you are looking for.
You could break the LED segment into shorter strips and assign the NeoPixels to multiple pins so you can back to back effects.
Another option would be to take a look at the FancyLED library which overs a lot of control and cool builtins.
https://learn.adafruit.com/fancyled-lib ... n/overview
comet = Comet(pixels, speed=0.01, color=PURPLE, tail_length=20, bounce=True)
while True:
comet.animate()
