I am using a Max31855 thermocouple with the adafruit k type thermocouple with the metal shield. I have this placed into an iron pipe stuffed with aluminum foil and a cartridge heater. The program is supposed to heat the pipe to a set temp then flip a relay on and off to maintain the temp. I used this code (i know its not circuitpython code its micropython) but was wondering if anyone had any ideas as to why it keeps throwing the "thermocouple not connected" error. It will work for a while maybe 5-10 minutes the it throws the error and I have to unplug and replug the rpi. This is inconvenient at best. the iron pipe is getting wet as I am bending wood with it but I dont see why this would cause an issue. No water is getting inside the box with the electronics.... any help appreciated.
from machine import SPI, Pin
import utime
import ustruct
class MAX31855:
Driver for the MAX31855 thermocouple amplifier.
MicroPython example::
import max31855
spi = SPI(1, baudrate=1000000)
cs = Pin(15, Pin.OUT)
s = max31855.MAX31855(spi, cs)
print(s.read())
def __init__(self, spi, cs):
self.spi = spi
self.cs = cs
self.data = bytearray(4)
def read(self, internal=False, raw=False):
Read the measured temperature.
If ``internal`` is ``True``, return a tuple with the measured
temperature first and the internal reference temperature second.
If ``raw`` is ``True``, return the values as 14- and 12- bit integers,
otherwise convert them to Celsuius degrees and return as floating point
numbers.
self.cs.low()
try:
self.spi.readinto(self.data)
finally:
self.cs.high()
# The data has this format:
# 00 --> OC fault
# 01 --> SCG fault
# 02 --> SCV fault
# 03 --> reserved
# 04 -. --> LSB
# 05 |
# 06 |
# 07 |
# > reference
# 08 |
# 09 |
# 10 |
# 11 |
# 12 |
# 13 |
# 14 | --> MSB
# 15 -' --> sign
# 16 --> fault
# 17 --> reserved
# 18 -. --> LSB
# 19 |
# 20 |
# 21 |
# 22 |
# 23 |
# > temp
# 24 |
# 25 |
# 26 |
# 27 |
# 28 |
# 29 |
# 30 | --> MSB
# 31 -' --> sign
if self.data[3] & 0x01:
raise RuntimeError("thermocouple not connected")
if self.data[3] & 0x02:
raise RuntimeError("short circuit to ground")
if self.data[3] & 0x04:
raise RuntimeError("short circuit to power")
if self.data[1] & 0x01:
raise RuntimeError("faulty reading")
temp, refer = ustruct.unpack('>hh', self.data)
refer >>= 4
temp >>= 2
if raw:
if internal:
return temp, refer
return temp
if internal:
return temp / 4, refer * 0.0625
return temp / 4
spi = machine.SPI(0, baudrate=80_000_000, polarity=0, phase=0, bits=8, sck=Pin(6), mosi=Pin(7), miso=Pin(4))
cs = Pin(5, Pin.OUT)
s =MAX31855(spi, cs)
#Variables for pin numbers
relay=22
powerLed=0
tempLed=1
#Temperature Settings
max=150
min=140
#Initialize pins
controller=machine.Pin(relay, machine.Pin.OUT)
power_led=machine.Pin(powerLed,machine.Pin.OUT)
temp_led=machine.Pin(temLed,machine.Pin.OUT)
#Turn on Power LED
power_led.high()
while True:
current_temp=s.read()
if current_temp>45:
temp_led.high()
if current_temp<min:
controller.high()
elif current_temp>max:
controller.low()
elif current_temp<=45:
temp_led.low()
controller.high()
controller.low()
time.sleep(5)
