Digital In/Out
ctmorrison
Digital In/Out
Post by ctmorrison »
If I want to use A2 on a QT PY as a digital input, do I merely need to set it up as follows:
switch = DigitalInOut(board.A2)
switch.direction = Direction.INPUT
switch.pull = Pull.UP
I'm also wanting to use A0 and A1 as digital output, so I'm assuming it would be similar to the above.
adafruit_support_carter
Re: Digital In/Out
Yep. Should work.
ctmorrison
Re: Digital In/Out
I'm getting an error on
Perhaps that's not supported on the QT PY A2 port?
Re: Digital In/Out
OK, that can happen. Internal pull ups are something that not all microcontrollers provide on their digital pins. Which QT PY are you using?
ctmorrison
Re: Digital In/Out
ESP32-S2
ctmorrison
Re: Digital In/Out
Also, if I want to use SDA as a digital input, do I simply declare it using something like
relayStatus = DigitalInOut(board.SDA)
neradoc
Re: Digital In/Out
Post by neradoc »
What error ? Did you import Pull ?
Please give us the full error.
Are your imports like this ?
from digitalio import DigitalInOut, Pull, Direction
ctmorrison wrote:Also, if I want to use SDA as a digital input, do I simply declare it using something like
Yes, it's just the pin name, it can be used for anything you want to do with the pin.
ctmorrison
Re: Digital In/Out
So...the pull error was my fault. I had previously done a
from digital import DigitalInOut, Direction, Pull
but had subsequently removed the Pull was it wasn't being used and threw an error (in Mu).
I ended up simply adding an external pulldown resistor.
Thanks for the assist.
