m0 Interrupt timer stepper control?
by AndyJar on Tue May 15, 2018 2:03 pm
Hey all! I'm wondering if it's possible to control a stepper driver (such as a StepStick or equivalent, which require STEP pulses) with the onboard timers of the m0 chip.
I ask because I'm trying to both write to an SPI OLED screen (via HW SPI) and drive a stepper at the same time--and I believe the timing of both is messing each other up. I can't get the stepper to behave either at all, or properly, and I'm thinking this may help.
Open to any and all suggestions!
AndyJar
Re: m0 Interrupt timer stepper control?
by adafruit_support_mike on Wed May 16, 2018 12:24 am
The microcontroller can definitely handle the job.. it has three Timer/Counter for Control peripheral instances specifically designed for it.
Those features don't have wrappers in the Arduino libraries though. You'll need to dig into the datasheets and low-level code to find the registers that you need to set for the kind of output you want to produce.
The SAMD21 datasheet is here:
https://www.adafruit.com/images/product ... asheet.pdf
and the best place to start looking in the code will be the file wiring_analog.c from the board support package:
https://github.com/adafruit/ArduinoCore ... g_analog.c
