starting with the dotstar off?
by sketchy on Wed Jul 11, 2018 8:52 am
i am not clear on what is probably an obvious thing.
i'm using arduino ide on itsy bitsy m0 express. i want to turn off as many peripherals / external components as possible. the dotstar is on when booting. other than importing the dotstar library, is there a "faster" "more efficient" way to turn off components like the dotstar?
also, if you have a reference for all the components/peripherals i should consider turning off (in m0 standby mode) for lowest power, i'd appreciate the link. i'm new to low power "isms" and "gotchas".
Thank you - as always - VERY MUCH.
sketchy
Re: starting with the dotstar off?
by aaronaverill on Wed Jul 11, 2018 9:08 am
You can talk to dotstars with SPI.
Here's my Circuit Python code for the Trinket M0 to turn off the dotstar which I imagine is very similar. Hopefully you can translate it to C.
# Turn off the internal dotstar
spi = SPI(board.APA102_SCK, board.APA102_MOSI)
while not spi.try_lock():
    pass
spi.configure(baudrate=4000000)
spi.write(bytearray([0,0,0,0,0xE0,0,0,0,0xFF]))
spi.deinit()
The important bytes are the array you send.
bytes 0-3 = four 0x00
byte 4 = three high bits set to 1 followed by five bits set to the brightness = 1110000 = 0xE0
byte 5-7 = BGR data (all 0x0)
byte 8 = terminating 0xFF
Hopefully this helps.
aaronaverill
by sketchy on Wed Jul 11, 2018 11:48 am
Thank you Aaron. I will give your code a twirl. Very much appreciate it.
I would prefer Circuit Python, but sadly Circuit Python currently does not support goodies like m0's standby mode. Have you done any work/play on other areas of low power w/ Circuit Python?
sketchy
by aaronaverill on Wed Jul 11, 2018 12:06 pm
sketchy wrote:Thank you Aaron. I will give your code a twirl. Very much appreciate it.
Please share the Arduino code if you have a chance and get it working.
sketchy wrote:I would prefer Circuit Python, but sadly Circuit Python currently does not support goodies like m0's standby mode. Have you done any work/play on other areas of low power w/ Circuit Python?
Yeah, the python is ridiculously fun + easy to work with. I came into the python first, and feel like I need to try Arduino just for a complete "experience" in microcontrollers, but... man... I told myself 20 years ago I would never write C++ code again... and I haven't yet found a need. :)
I haven't done anything with sleep modes in python but that team is very responsive to requests and I imagine contributed code would be appreciated.
aaronaverill
by languer on Sat Jul 14, 2018 12:47 am
This post gives you some ideas on low power operation on the trinket.
viewtopic.php?f=52&t=135218&p=677387#p677387
languer
by sketchy on Sat Jul 14, 2018 7:10 am
That is very helpful. Thank you for your kind post.
sketchy
