Only getting 2.75V from Pin 5
by tlschumacher2000 on Thu May 28, 2020 11:17 pm
I'm running the Strandtest for the M4 and seeing nothing. I've verified the ws2812b string is working by plugging it into a Pro Mini.
So I decided to see if the ItsyBitsy M4 was putting out 5V on pin 5 with this program.
#define PIN 5 // this is the 5v output pin
#define ledPin 13
// put your setup code here, to run once:
pinMode(ledPin, OUTPUT);
pinMode(PIN, OUTPUT);
// put your main code here, to run repeatedly:
digitalWrite(ledPin,HIGH);
digitalWrite(PIN,HIGH);
delay(3000);
digitalWrite(ledPin,LOW);
digitalWrite(PIN,LOW);
delay(3000);
When I put a volt meter between pin 5 and ground, it goes between 0 and 2.74v then back to 0.
Am I missing something here? I thought Pin 5 was the high voltage output so I could drive the LED strip directly.
Inquiring minds would like to know.
Terry
tlschumacher2000
Re: Only getting 2.75V from Pin 5
by dastels on Thu May 28, 2020 11:33 pm
D5 is level shifted to whatever the supply voltage is: 5v if you have USB connected, that will be close to 5v, a bit less than the battery voltage if you just have a battery connected.
dastels
by tlschumacher2000 on Sat May 30, 2020 12:22 am
Thanks Dave
Upon further investigation, I discovered those voltages were with USB and the light strip WAS connected. If I disconnected the lightstrip the voltage was back up to 5v.
I'm not sure the strip should be pulling it down like that. More investigation is needed.
Terry
(how do I mark the question as solved? I have another posting that was solved also)
tlschumacher2000
by adafruit_support_bill on Sat May 30, 2020 6:07 am
Pin 5 is a GPIO pin. It can put out 5v logic levels, but it is not capable of supplying enough current to power a strip. You should power your strip from the USB pin and use pin 5 as your signal pin for the strip.
