Error Uploading code
by KeyboardDR on Tue Jul 07, 2020 3:40 pm
So we bought 2 of these: https://www.adafruit.com/product/3677 (ItsyBitsy 32u4 - PRODUCT ID: 3677) so that we could auto enroll our chromebooks at the school I work at. 1 of the 2 works completely fine. However, the other get's an error that reads
Error uploading, check if the selected board is currently available.
If you need pictures of it I can get them, they're just too large.
KeyboardDR
Re: Error Uploading code
by mikeysklar on Tue Jul 07, 2020 3:50 pm
Hello KeyboardDR,
There are three likely possibilities here:
1. Make sure you are selecting your exact board from the Arduino IDE. There is a 3v and 5v version with a 8MHz and 16MHz option.
2. There is a required Windows driver depending on your Win version.
https://learn.adafruit.com/introducting ... rduino-ide
3. You must be using a valid USB Data cable. You can verify it with another microcontroller or USB storage device if you are unsure, but a random USB charge only cable is the most common reason for a board not being detected.
mikeysklar
by KeyboardDR on Wed Jul 08, 2020 3:43 pm
I have the correct board.
It's not a driver issue as I can program the other exact same model just fine.
cable is good as I used it for the other itsybitsy.
KeyboardDR
by mikeysklar on Wed Jul 08, 2020 3:55 pm
Gotcha.
Since you have two units and one works and the other does not (I assume on the same chromebook setup for both) we will get you a replacement if you qualify. When did you purchase these boards and was it through Adafruit?
mikeysklar
by KeyboardDR on Thu Jul 09, 2020 9:29 am
I work for a school and it arrived July 2nd but we don't do the ordering. We're assuming it was ordered a week before that date. If you need concrete times I can see if I can get them.
KeyboardDR
by KeyboardDR on Thu Jul 09, 2020 9:30 am
Also, an unrelated note but my timestamps are incorrect. That lost post I sent was around 9:23am. I checked my timezone setting in my account and it is correct. It's set to Eastern US. Just thought I'd let you know.
KeyboardDR
by mikeysklar on Thu Jul 09, 2020 12:54 pm
Our timezone stuff is not functional in the forums. Apparently it is a rather complicated issue to resolve.
If you can get the order# for your Itsy Bitsy's you can send an e-mail to support@adafruit.com and link them to this forum thread with the order# in the e-mail and they will send you a replacement board.
mikeysklar
by KeyboardDR on Thu Jul 09, 2020 2:52 pm
Ok thank you very much! I'm trying to acquire the order number now.
KeyboardDR
