Hallowing M4 Display shows lines instead of the eye
by diegomoises1 on Sat Oct 17, 2020 10:23 pm
My M4 just arrived today and it worked perfectly on first plug, a few minutes later though the eye went away and all I saw were lines that move like the eye used to. It is completely dark in the middle with lines around that move as if it was still running the eye. I have updated the bootloader, I can access the bootloader no problem by double tapping reset, and the leds work when I use the Hallowing Rainbow UF2 but the display does the same thing. I have also tried using the arduino IDE and the same problem persists. I can use the diagnostics UF2 and everything on the board seems to work fine. Could something have happened to the display?
diegomoises1
Re: Hallowing M4 Display shows lines instead of the eye
by diegomoises1 on Sun Oct 18, 2020 11:16 am
Here is a picture of the display running the graphicstest_hallowing_m4 arduino code.
diegomoises1
by diegomoises1 on Sun Oct 18, 2020 11:59 am
Fixed! Took out the display and plugged it back in carefully, some pins might have come off during handling. All working well now.
diegomoises1
