QT Pi RP2040 SPI ?
QT Pi RP2040 SPI ?
by James_Purcell on Fri May 14, 2021 7:38 am
Please excuse this perhaps stupid question but my brain is filing to see the answer.
I have a Raspberry Pico running circuit python and Todbots GC9A01 python code on pins 10-15.
I would like to replace the Pico with the QT PI RP2040 due to its physically small size (I don't have the courage to spin up a whole new board). Can I still run an SPI (3v3) display on the QY PI RP2040 by just changing the defined pins in Circuit python?
James_Purcell
Re: QT Pi RP2040 SPI ?
by blnkjns on Fri May 14, 2021 7:47 am
From the docs:
SPI and UART peripherals, in standard QT Py locations,
https://www.adafruit.com/product/4900
Use one of A0-A3 as CS pin
blnkjns
by James_Purcell on Sun May 16, 2021 4:40 am
Thank you for taking the time to clear up my confusion.
James_Purcell
by adafruit_support_carter on Tue May 18, 2021 2:50 pm
Yep, should just work with a pin renaming in the original code to match your QT Py connections.
