I started with the code from this tutorial on sprite-based animation, adapted for a 64x64 display and my own 64x64 sprites: https://learn.adafruit.com/pixel-art-ma ... on-display.
I have the small STEMMA-QT speaker breakout board that I would like to play sound over while the display is animating. My naive approach of simply adding the playback to the main loop gave me incredibly choppy audio playback thanks to (I assume) the time.sleep call used to set the animation framerate. Fair enough.
My next approach was to use the asyncio library to allow the sound to keep playing while the animation waits for its next frame. This gave potentially slightly better audio outbut but it's still pretty awful. It seems that re-rendering the entire 64x64 display 10 times a second simply requires too much processor time to allow audio playback over an analog pin at the same time.
Is this conclusion correct? My current thought is that offloading sound playback to something like the FX sound board (https://www.adafruit.com/product/2133) is the best solution, but if I'm missing something and doing full-screen animations alongside smooth audio playback is possible without extra hardware I'm all ears!
For reference, here's my code in full
import time
import os
import asyncio
import audioio
import board
import displayio
from adafruit_matrixportal.matrix import Matrix
from audiocore import WaveFile
import adafruit_nunchuk
displayio.release_displays()
BACKGROUND_BMP = displayio.OnDiskBitmap("/bmps/momo.bmp")
IDLE_BMP = displayio.OnDiskBitmap("/bmps/idle.bmp")
SPEAKING_BMP = displayio.OnDiskBitmap("/bmps/speaking.bmp")
VOICE_WAV = "/voice/voice.wav"
class FullscreenSprite:
def __init__(self, sprite_bitmap, background_bitmap, frame_delay):
self.group = displayio.Group()
self.current_frame = 0
self.frame_delay = frame_delay
self.sprite_bitmap = sprite_bitmap
self.frame_count = int(sprite_bitmap.width / 64)
self.background_bitmap = background_bitmap
colors = displayio.ColorConverter()
colors.make_transparent(0)
self.background = displayio.TileGrid(
background_bitmap,
pixel_shader=colors,
tile_width=64,
tile_height=64
self.sprite = displayio.TileGrid(
sprite_bitmap,
tile_width=64,
tile_height=64
self.group.append(self.background)
self.group.append(self.sprite)
async def advance_frame(self):
self.current_frame = self.current_frame + 1
if self.current_frame >= self.frame_count:
self.sprite[0] = self.current_frame
await asyncio.sleep(self.frame_delay)
async def audio_player():
speaker = audioio.AudioOut(board.A0)
wav = WaveFile(open(VOICE_WAV, "rb"))
speaker.play(wav, loop=True)
async def animate_face():
matrix = Matrix(bit_depth=4, width=64, height=64)
idle_sprite = FullscreenSprite(IDLE_BMP, BACKGROUND_BMP, 0.1)
current_sprite = idle_sprite
matrix.display.show(current_sprite.group)
while True:
await current_sprite.advance_frame()
async def main():
animation_task = asyncio.create_task(animate_face())
audio_task = asyncio.create_task(audio_player())
await asyncio.gather(animation_task, audio_task)
asyncio.run(main())
