Help using Itsy for a module controller.
by Yacob454 on Tue Jan 30, 2018 1:13 pm
Hey how's it going? I'm interested in the Itsy, the Rasberry Pi Zero (or any other) to control a heated seat module in a truck (12 volt system). My question is can I program The Itsy to control power outputs for network communications? I have a lot of reference material attached to help. The module is a Ford heated/cooled seat control module. The part number for it is BU5Z-14C724-A. It has two MS CAN signal wires, one positive and one negative. It has a resting state of 2.5v on both wires and increases/decreases by 1.0v on a given wire to signal an activation of the seat module. I have added a few pictures for reference and can email much more. Thank you for your help.
Yacob454
Re: Help using Itsy for a module controller.
by adafruit_support_mike on Thu Feb 01, 2018 4:33 am
The Itsy Bitsy doesn't support CAN directly, and we don't have any CAN peripherals, but peripherals do exist and a microcontroller will be able to talk to them.
The Itsy Bitsy won't be an all-in-one solution though.
by Yacob454 on Thu Feb 01, 2018 1:44 pm
Awesome answer. What type of peripheral device would I require to operate CAN?
Yacob454
by Yacob454 on Thu Feb 01, 2018 3:29 pm
Added more info
Yacob454
by adafruit_support_mike on Fri Feb 02, 2018 1:34 am
It looks like these are some of the most common CAN interface chips:
https://www.digikey.com/products/en/int ... ageSize=25
From what I can see in a quick scan of the datasheets, the CAN bus uses differential signals (one goes high when the other goes low and vise-versa), and the transciever converts between that and the regular high/low signals a microcontroller would use. You'll still need to find code to generate the signals that tell the connected device what to do.
by Yacob454 on Fri Feb 02, 2018 11:56 am
Awesome thank you for your help. This seems like a project way beyond my abilities. Are there people or companies out there that specialize in doing custom things such as this?
Yacob454
by adafruit_support_mike on Sun Feb 04, 2018 3:04 am
There are design houses, but they'll probably be pricey for a single device.
Check to see if there's a hackerspace near you, or a community college with an electronics program. Those are good places to find people willing to take on a small paid project.
by Yacob454 on Sun Feb 04, 2018 12:48 pm
Awesome. Thank you again for all your help.
Yacob454
