ITSY BITSY 32U4 5v 16MHz PlatformIO
by sophtware on Mon Feb 26, 2018 3:11 pm
I have recently moved over to using Atom and PlatformIO for my Arduino development. I just received 2 ITSY boards, but the device is not listed in PlatformIO. Is there a file I need to import to make them available, or should I select from one of the other available Adafruit boards?
sophtware
Re: ITSY BITSY 32U4 5v 16MHz PlatformIO
by adafruit_support_mike on Tue Feb 27, 2018 5:50 am
You should be able to make it work using the Arduino Leonardo build target. That's also a 32u4 dev board, and the Arduino framework has pin assignments for all the pins on the chip.
It looks like you could also copy the information for the Flora or Feather 32u4 and create a JSON data structure for the Itsy:
http://docs.platformio.org/en/latest/pl ... -structure
As soon as you have the name and the ability to associate that with the Arduino framework, I think you'll get access to the whole board support package.
by sophtware on Tue Feb 27, 2018 10:26 am
Thanks! I'll try that. If I create the JSON file for the board, can I pass it on to Adafruit so others can benefit from it too?
sophtware
by adafruit_support_mike on Thu Mar 01, 2018 4:43 am
Sure, you can post it here.
We aren't associated with PlatformIO though, and it would be good to give them a copy too.
