Feather 32u4 won't scan RFID using MFRC522
by rjpatel2 on Sun Apr 08, 2018 8:32 pm
I am trying to make an alarm system where once the alarm goes off, you can turn it by scanning a RFID tag. I am using the following pin connections:
MFRC522---------------Arduino Uno
SDA------------------------ Digital 10 (SS)
SCK------------------------Digital 13 (SCK)
MOSI----------------------Digital 11 (MOSI)
MISO----------------------Digital 12(MISO)
IRQ------------------------unconnected
GND-----------------------GND
RST------------------------Digital 9 (PB1/OC1A)
3.3V------------------------3.3V
These are the connections between MFRC522 and Arduino Uno R3. I am using the same connections for Feather 32u4 basic proto. My problem is that the RFID scans and reads a tag normally. But when the alarm goes off, the RFID does not scan at all. I am using a Real Time Clock module to get time and use a function that constantly compares the current time with the set alarm time. Is there something I should know about Feather 32u4 while trying to get it to scan using RFID while is is already busy performing some other activity?
rjpatel2
Re: Feather 32u4 won't scan RFID using MFRC522
by kcl1s on Sun Apr 08, 2018 11:18 pm
Post your code (between code tags) and we can take a look. Does your sketch work on the Uno when the alarm is active?
Fellow Hobbyist
Keith
kcl1s
by rjpatel2 on Mon Apr 09, 2018 7:38 pm
I managed to figure it out. The RST for mfrc522 was using the same port 9 as button A on featherwing oled display we were using. Button A had to be pressed to set the alarm so everytime button A was pressed it messed up the reset setting for the mfrc522 as well thus stopping it from scanning again until you reset the whole product.
rjpatel2
