Itsy Bitsy 32u4 analog input pins
by amowry on Tue Apr 10, 2018 2:50 pm
In the description for this board it says that it has 6 analog/digital pins and 17 digital pins. Can't more of the digital pins be used as analog inputs, since the chip has 12 total analog inputs? Can the additional analog pins be called out in the Arduino IDE as A6-A11? Thanks!
amowry
Re: Itsy Bitsy 32u4 analog input pins
by adafruit_support_carter on Wed Apr 11, 2018 1:51 pm
Yes. I think by "pins" it's meaning the actual pins dedicated to analog input, the ones labeled A0 thru A5. The digital pins that also have analog input capability are mentioned in the pin out description here:
https://learn.adafruit.com/introducting ... logic-pins
by amowry1 on Wed Apr 11, 2018 5:48 pm
Okay, thanks! I guess it follows the Leonardo convention, where only 6 pins are labeled on the board as analog.
amowry1
