M0 Feather ... Where to initialize a LED ?
by MogaRaghu on Sun Apr 15, 2018 5:57 am
Reading my issue may raise eyebrows.. its simple. I have a M0 Bluefruit Feather and i am trying to add a LED to one of the examples. Funnily within Setup(void) , the position of the statement where i Declare the LED is critical or it seems so. Look at the attached code below in which the LED works as expected . But if i shift it below just before where Setup ends, it does not work. Any reason for this behaviour ??
void setup(void)
  pinMode(ledFlash, OUTPUT);                        // If declared here the LED works !!
  digitalWrite( ledFlash, HIGH);
  Serial.begin(9600);
  Serial.println(F("Adafruit Bluefruit Command <-> Data Mode Example"));
  Serial.println(F("------------------------------------------------"));
  Serial.print(F("Initialising the Bluefruit LE module: "));
  if ( !ble.begin(VERBOSE_MODE) )       //  Start the BLE module.
    error(F("Couldn't find Bluefruit, make sure it's in CoMmanD mode & check wiring?"));
  Serial.println( F("OK!") );
  ble.echo(false);
  Serial.println("Requesting Bluefruit info:");
  ble.info();
  Serial.println(F("Please use Adafruit Bluefruit LE app to connect in UART mode"));
  Serial.println(F("Then Enter characters to send to Bluefruit"));
  Serial.println();
  ble.verbose(false);
  while (! ble.isConnected())
    delay(500);
  Serial.println(F("******************************"));
  if ( ble.isVersionAtLeast(MINIMUM_FIRMWARE_VERSION) )
    Serial.println(F("Change LED activity to " MODE_LED_BEHAVIOUR));
    ble.sendCommandCheckOK("AT+HWModeLED=" MODE_LED_BEHAVIOUR);
  Serial.println( F("Switching to DATA mode!") );
  ble.setMode(BLUEFRUIT_MODE_DATA);
  //pinMode(ledFlash, OUTPUT);                                  // If  declared here, LED does not work !!
  //digitalWrite( ledFlash, HIGH);
MogaRaghu
Re: M0 Feather ... Where to initialize a LED ?
by kcl1s on Sun Apr 15, 2018 8:18 am
This part of code will keep the LED from initializing (or run any more code) until you have a ble connection.
    delay(500);
Fellow Hobbyist
Keith
kcl1s
by MogaRaghu on Wed Apr 18, 2018 4:45 am
kcl1s wrote:This part of code will keep the LED from initializing (or run any more code) until you have a ble connection.
    delay(500);
Fellow Hobbyist
Keith
Spot on. Missed that line !!
Thanks Keith.
MogaRaghu
