I just rigged up a test circuit to begin the process of making my Itsy talk to another Arduino as a slave processor. The code (below) is simple at this stage... just send a message.. receive it... and print on the console. It's working just fine. Although I have issues with the IDE. But my question is related to the picture I uploaded. Why is the Itsy powered at all when the only connections to it are a GND line and the Tx/Rx wires to 0 & 1. As you can see in the pix, the red led is on and blinking as the sketch tells it to. And no USB or batt or 5v power is being supplied. So where's the power coming from? I can't believe it's pulling juice from the Rx line sufficient to power itself. And if it is I don't want it to. Comm lines should not be supplying power.
Let me know when you get a minute. Thanks.
====Itsy Code=========
#include <Arduino.h>
#include <stdlib.h>
#include <math.h> // AVG math library for calculations
Serial1.begin(19200);
pinMode(13, OUTPUT);
Serial1.println("Hello, this is Itsy");
digitalWrite(13, HIGH); // turn the LED on
delay(250); // wait for a bit
digitalWrite(13, LOW); // turn the LED off
delay(1750);
======Arduino Code===============
#include <SoftwareSerial.h>
SoftwareSerial ItsyLink(9, 8) ;
Serial.begin(115200);
ItsyLink.begin(19200);
Serial.println("Ard Side Starting");
delay(2000);
if(ItsyLink.available()){
char c = ItsyLink.read();
Serial.print(c);
Power mystery
Re: Power mystery
The ItsyBitsy is getting power from its RX pin.
That's kind of a party trick with microcontrollers:
https://www.youtube.com/watch?v=2yFh7Vv ... el=EEVblog
The pins have voltage protection circuits that route voltages higher than the VCC pin to the positive internal supply rail, and voltages lower than the GND pin to the internal negative supply rail. If nothing is connected to VCC but a GPIO pin is connected to some positive voltage, a small amount of current will flow through the protection circuit to the internal supply rails. It only takes a few microamps to make a chip run, so the leakage will power the chip.
- khorner116
Re: Power mystery
Very interesting indeed. Never would have occurred to me. But thanks for the answer, I can now design around it. I thought for a minute I had a bad test board.
