Hi fellow Makers....
I'm working on the "Timelapse Spy Camera" tutorial, but instead of a Trinket 3V/5V, I'm going to use an Itsy Bitsy 32u4 3V 8 Mhz; since its USB friendly and its cheaper and smaller than a Feather.
In this Mod project, I'm going to have TWO boards connected to each other by wires until I buy Two Bluetooths to pair them up in communitation; the Arduino will control the Cellular chip for communication, and the Itsy Bitsy will control the Mini Spy Camera. (I don't want to keep the Arduino waiting to free up time to control the camera, that's why I'm using two Microcontrollers)
EDIT***
I'm using a signal converter from 5V to 3V to condition the Arduino 5V digital logic High pin to 3V signal logic level for the Itsy Bitsy digital pin.
My question is do I have to connect the Gounds of the Two boards together to properly communicate with each other through digital pins? I'm pretty sure I do, but I just want to make sure, theres the diffirence of potential on the power supplys; Arduino 5v, Itsy Bitsy 3V.
Thanks.
Ground circuit question regarding Itsy Bitsy 32u4 3V
- Blueshark
- danhalbert
Re: Ground circuit question regarding Itsy Bitsy 32u4 3V
Yes, connect the grounds together, so that they share a common reference voltage (ground), and so that that current can flow between the pins and ground.
- Blueshark
Thank You Admin danhalbert
