Hi! I recently soldered up an Itsy Bitsy M0. When it's plugged in to USB, it appears as a disk and the lights light up.
When I use my multimeter on the 3V pin I see 3.2V as I'd expect.
When I switch the multimeter to test any of the BAT, USB, or Vhi pins, I get zero volts.
Did I fry something accidentally? Is there any recovery from this?
The solder joints all look ok. I don't see any pins being bridged or anything.
Thanks in advance for any help.
Itsy Bitsy M0 no BAT/USB/Vhi
Re: Itsy Bitsy M0 no BAT/USB/Vhi
Post a photo showing your hardware and the connections you're using to measure, say, the voltage on the BAT pin please. 800x600 images usually work best.
- fionawhim
I have photos of 3V working and Vhi and USB at 0 volts. I'm powering it over USB so I guess I wouldn't expect anything on BAT.
I tried another Itsy-Bitsy (not pictured) and Vhi and USB were 5v with the same setup.
Thanks for your time!
- Attachments
- USB not working
- IMG_2918.jpg (108.6 KiB) Viewed 291 times
- Vhi not working
- IMG_2917.jpg (114.12 KiB) Viewed 291 times
- 3v working
- IMG_2916.jpg (113.57 KiB) Viewed 291 times
- BryonMiller
Your voltmeter is not saying 0 V (which I believe would show up as 0.000), instead it is saying OF (that's a capital O, capital F). OF stand for OverFlow and it means that the input signal has exceeded the maximum input as determined by your Range. It appears your Range is set to 4 volts, which is fine for the 3.3 v reading but not so good for voltages closer to 5 volts.
- fionawhim
Ah, thank you.
That is true, and I tried again with it in set to "auto" range and it now reads as 5v. For some reason I had given myself the impression that the range control worked in powers of 10, rather than a cutoff at 4v.
I think my original problem (NeoPixels not appearing to get power when plugged in to Vhi) may have been due to some flaky jumper cables. I then confused myself into thinking it was the microcontroller because I wasn't using the multimeter correctly.
Thanks again for your time and response! It looks like my Itsy Bitsy is actually just fine.
Glad to hear things are working, or at least that you're getting closer to making them work. Happy hacking!
- artman70
Which pin (gpio) can i read in code to get bat voltage on the ItsyBitsy M0?
couldnt find the reference...
thanks in advance
thanks in advance
There's no built-in voltage monitor pin on the ItsyBitsy. You can connect a 100k-100k voltage divider between BAT and GND then read the voltage at the center of the divider with any of the analog inputs.
