A bit new at this. Are arrays supposed to retain data when the 32U4 is powered down? I am using four arrays with 10 cells each. Can get the data into the arrays just fine, but loose it when powering down. There are a couple of other problems, but if this one can't be solved there is no use going further.
Any suggestions appreciated,
Frank
Arrays don't retain data on power down
- adafruit_support_carter
Re: Arrays don't retain data on power down
In general, no. They are typically stored in volatile memory, so will disappear when power is removed (that's the volatile part). If you want the data to persist between power cycles, you will need to store it in some form of non-volatile memory. The 32u4's have a limited amount of EEPROM you may be able to use:
https://learn.adafruit.com/memories-of- ... ino/eeprom
- Frank87a
I went to the Arduino Reference and don't see the ATmrga32u4 listed as a compatible device. just want to make sure that the " #include <EEPROM.h> will work with the 32u4 before I try and figure out how to use it. Will the EEPROM library work with the 32u4?
Thanks, Frank
EEPROM Library
The microcontroller on the Arduino and Genuino AVR based board has EEPROM: memory whose values are kept when the board is turned off (like a tiny hard drive). This library enables you to read and write those bytes.
The supported micro-controllers on the various Arduino and Genuino boards have different amounts of EEPROM: 1024 bytes on the ATmega328P, 512 bytes on the ATmega168 and ATmega8, 4 KB (4096 bytes) on the ATmega1280 and ATmega2560. The Arduino and Genuino 101 boards have an emulated EEPROM space of 1024 bytes.
Thanks, Frank
EEPROM Library
Should work. Here's an example that uses EEPROM on a 32u4:
https://learn.adafruit.com/how-cold-is- ... ure-logger
- Frank87a
Haven't tried to use the <EEPROM.h> function yet. My question is, do I need to provide the .>= 3.3 msec delays for each byte that I write or does <EEPROM.h> some how take care of it?
Thanks Frank
Thanks Frank
Check out the logger source code from that guide.
- Frank87a
Two different EEPROM write candidates. lines 800-806 and 809-815
Lines 800-806 compile with no errors. If this method is a valid way to save the arrays on power down, then I would simply read the EEPROM back to the arrays like, ant1 = EEPROM....etc. on power up.
lines 809-814 will not compile when using "EEPROM.write. line 811.
The error message from line 811 was "no matching function for call to EEROMClass::write(int&)"
I saw the "::" in the error message and substituted that for the "." after the write and
lines 812-814 seem to compile OK, no matter how many colons I put in there.. Don't know if anything useful will result. Tried to find the meaning of "::" in the Arduino Ref but could't find it. If this method is workable, then I think I should have the choice of reading the data directly from EEPROM easily, or reading it back to the arrays on power up.
My question is, will either of these approaches work?
Any direction here on which method is would be appreciated.
Nothing tested yet. Would need to write some code to avoid getting into a EEPROM write loop.
Thanks - Frank
800 for (int i=0; i<= 9; i++) // There are 10 cells/array
EEPROM[0+i]=ant1;
EEPROM[10+i]=ant2;
EEPROM[20+i]=ant3;
EEPROM[30+i]=ant4;
806 }
809 for (int i=0; i<= 9; i++)
EEPROM.write(EEPant1=ant1);
EEPROM:::write(EEPant2=ant2);
EEPROM::write(EEPant3=ant3);
EEPROM:write(EEPant4[i]=ant4[i]);
815 }
[The extension ino has been deactivated and can no longer be displayed.]
See code linked above for example of how to read and write to EEPROM. The library documentation is also good:
https://www.arduino.cc/en/Reference/EEPROM
