import board
import gc
import time
from digitalio import DigitalInOut, Direction, Pull
import adafruit_dotstar
import rotaryio
gc.collect()
dot = adafruit_dotstar.DotStar(board.APA102_SCK, board.APA102_MOSI, 1, brightness=0.2)
encoder = rotaryio.IncrementalEncoder(board.D10, board.D9)
# Helper to give us a nice color swirl
def wheel(pos):
# Input a value 0 to 255 to get a color value.
# The colours are a transition r - g - b - back to r.
if (pos < 0):
return [0, 0, 0]
if (pos > 255):
return [0, 0, 0]
if (pos < 85):
return [int(pos * 3), int(255 - (pos*3)), 0]
elif (pos < 170):
pos -= 85
return [int(255 - pos*3), 0, int(pos*3)]
else:
pos -= 170
return [0, int(pos*3), int(255 - pos*3)]
last_position = None
i = 0
while True:
dot[0] = wheel(i & 255)
i = (i+1) % 256
position = encoder.position
if last_position is None or position != last_position:
print(position)
last_position = position
