ItsyBitsy M0 Express, CircuitPython 3.1.2, and rotaryio
DaemonMaker
Post by DaemonMaker »
I am trying to use a rotary encoder with an ItsyBitsy M0 Express. As per the Rotary Encoder with CircuitPython post by Kattni Rembor I have updated CircuitPython to 3.1.2 and updated the CircuitPython libraries to v3. I have created a simple script that does two things. First, it rotates the onboard dotstar through the rainbow and second, it reads the rotary encoder and prints the encoder.position (see below). While the dotstar functions as expected, turning the rotary encoder does not yield a change in the encoder.position value. Any insight as to why this would be the case would be appreciated.
import board
import gc
import time
from digitalio import DigitalInOut, Direction, Pull
import adafruit_dotstar
import rotaryio
gc.collect()
dot = adafruit_dotstar.DotStar(board.APA102_SCK, board.APA102_MOSI, 1, brightness=0.2)
encoder = rotaryio.IncrementalEncoder(board.D10, board.D9)
# Helper to give us a nice color swirl
def wheel(pos):
    # Input a value 0 to 255 to get a color value.
    # The colours are a transition r - g - b - back to r.
    if (pos < 0):
        return [0, 0, 0]
    if (pos > 255):
        return [0, 0, 0]
    if (pos < 85):
        return [int(pos * 3), int(255 - (pos*3)), 0]
    elif (pos < 170):
        pos -= 85
        return [int(255 - pos*3), 0, int(pos*3)]
    else:
        pos -= 170
        return [0, int(pos*3), int(255 - pos*3)]
last_position = None
i = 0
while True:
  dot[0] = wheel(i & 255)
  i = (i+1) % 256
  position = encoder.position
  if last_position is None or position != last_position:
    print(position)
  last_position = position
adafruit_support_carter
Re: ItsyBitsy M0 Express, CircuitPython 3.1.2, and rotaryio
Let's focus on just the encoder. Does it also not print out if you run the simple example from the guide?
https://learn.adafruit.com/rotary-encoder/circuitpython
If so, post a photo of your setup showing how everything is connected.
DaemonMaker
That's correct, the simple code from the guide does not work either.
Here a few photos from different angles:
You need to solder on the header pins. They are not making good electrical contact.
Return to “Itsy Bitsy Boards”
