m4 with spi library
m4 with spi library
by lavericklavericklaverick on Mon Jun 22, 2020 6:53 pm
hi, im using the adafruit adxl343 libary for arduino, i was using it on a feather m0 and have switched to an m4 itsybitsy, wiring exactly the same, however now the sensor isnt found by the code.
i noticed that the pin setup is different for m4 - do i need to go and change this in one of the libraries or is this dealt with by the compiler?
many thanks
Re: m4 with spi library
by lavericklavericklaverick on Tue Jun 23, 2020 3:52 am
Solved: me, just being a dummy (again)
Didnt realise that you could actually address the pins as miso, mosi and sck in the actual code - i thought you had to use a pin number.
all solved now. this chip is so fast! :)
