Hardware Interrupt M4 SAMD51 ItsyBitsy
by lavericklavericklaverick on Wed Jul 22, 2020 7:54 am
Im trying to accurately measure time between on and off of a digital signal.
Ive made a little test setup... I have a feather M0 running the blink example, this is connected to the input of the board running the hardware interrupt code, which calculates the time between on and off.
Interrupt code:
const byte LED = 13;
const byte BUTTON = 2;
int on;
int off;
// Interrupt Service Routine (ISR)
void switchPressed ()
  if (digitalRead (BUTTON) == HIGH) {
    on = micros();
    digitalWrite (LED, HIGH);
    //Serial.println(on);
  else {
    off = micros();
    digitalWrite (LED, LOW);
    Serial.println(off - on);
  }  // end of switchPressed
void setup ()
  Serial.begin(9600);
  pinMode (LED, OUTPUT);  // so we can update the LED
  digitalWrite (BUTTON, HIGH);  // internal pull-up resistor
  attachInterrupt (digitalPinToInterrupt (BUTTON), switchPressed, CHANGE);  // attach interrupt handler
}  // end of setup
void loop ()
  // loop doing nothing
Using an oscilloscope i can see the input is around 99.965ms
I have tested this with a Due and the M4 @ 120Mhz and 200MHz with the following results
I would have expected the M4 to be the most accurate @200MHz, however the Due outperforms it running @84MHz.
Does anyone know why this might be? Or have a solution to make the M4 more accurate?
Many thanks,
Andrew
