Feather 32u4 with RFM69HCW Packet Radio - 433MHz
jb85463
Post by jb85463 »
Hi all,
I am having a Feather 32u4 with RFM69HCW Packet Radio - 433MHz, I also bought some keyfobs with the same frequency. Since both using same RF 433 MHZ, Can I use the remote to control my feather? If yes, please help me how to set it up.
any help is pleasure!
mikeysklar
Re: Feather 32u4 with RFM69HCW Packet Radio - 433MHz
Post by mikeysklar »
Hello jb85463,
Depending on the keyfobs you are using there might already be a fully developed library for interacting with them.
I would suggest putting your RFM69 into OOK mode and start listening to the transaction to see what you can learn about them.
https://github.com/adafruit/RadioHead/b ... 69.cpp#L81
Joachim_Bnt
Post by Joachim_Bnt »
I think I have sort of the same issue. So I'm trying to use a key fob with the Feather 32u4 RFM69, so I've tried to use the code you share in the github, but my Arduino IDE says it couldn't compile.
Also, I don't know how to "listen to the transaction", if I understand well, I could "listen" which signals are sent, and then ask the Feather to react to them? How should I do that?
I'm sorry I'm really a beginner with radio module and Arduino in general, but I have to understand, or at least make it work, for a school project.
Thank you very much
mikeysklar
This sounds like a different issue.
Let's start with getting your code to compile. Please open a new thread on getting the 32u4 RFM69 example code to compile and we can work from there.
Return to “Itsy Bitsy Boards”
