aesio module for feather M4 express?
d0773d
Post by d0773d »
Does the feather m4 express support aes encryption? I checked the built-in modules section on https://circuitpython.org/board/feather_m4_express/ for aesio and I don't see support for aesio.. I'm looking for an example of how to encrypt/decrypt using aes.
d0773d
Re: aesio module for feather M4 express?
Post by d0773d »
I'm attempting to run a basic aes-ecb encryption example from the docs. Yes, I know cbc or ctr is a better choice for encryption.
import aesio
from binascii import hexlify
key = b'Sixteen byte key'
inp = b'Circuit Python!!' # Note: 16-bytes long
outp = bytearray(len(inp))
cipher = aesio.AES(key, aesio.mode.MODE_ECB)
cipher.encrypt_into(inp, outp)
hexlify(outp)
print(outp)
d0773d
Post by d0773d »
I probably should have placed this thread into the circuit python section. My apologies.
42volts
Post by 42volts »
From the SAMD51 datasheet;
BANNED
• One Advanced Encryption System (AES) with 256-bit key length and up to 2 MB/s data rate
– Five confidential modes of operation (ECB, CBC, CFB, OFB, CTR)
– Supports counter with CBC-MAC mode
– Galois Counter Mode (GCM)
• True Random Number Generator (TRNG)
• Public Key BANNED Controller (PUKCC) and associated Classical Public Key BANNED Library
(PUKCL)
– RSA, DSA
– Elliptic Curves BANNED (ECC) ECC GF(2n), ECC GF(p)
• Integrity Check Module (I CM) based on Secure Hash Algorithm (SHA1, SHA224, SHA256), DMA assisted
d0773d
Post by d0773d »
42volts wrote:From the SAMD51 datasheet;
BANNED
(PUKCL)
– RSA, DSA
Thank you for replying. This is good to know. Is it possible to utilize the built-in encryption support using CircuitPython for the feather m4 express? I attempted to use the example aesio code from https://circuitpython.readthedocs.io/en ... index.html, but there was an error: ImportError: no module named 'aesio' I searched through the libs located inside my downloaded Bundle Version 6.x and i didn't find an aesio module. So, I'm assuming aesio isn't supported for the feather m4 express?
42volts
Post by 42volts »
d0773d wrote:Is it possible to utilize the built-in encryption support using CircuitPython for the feather m4 express? I attempted to use the example aesio code from https://circuitpython.readthedocs.io/en ... index.html, but there was an error: ImportError: no module named 'aesio' I searched through the libs located inside my downloaded Bundle Version 6.x and i didn't find an aesio module. So, I'm assuming aesio isn't supported for the feather m4 express?
I couldn't answer that since I don't and won't ever use [circuit]python. If they offer you some way to access the registers, then I'd say YES FOR SURE. If not, then you're stuck with whatever support somebody has written for it.
Good luck!
d0773d
Post by d0773d »
Got it. Thank you. Hopefully, I can, if not then maybe I can achieve encryption using arduino? For now, I will wait for another response....
Return to “Itsy Bitsy Boards”
