- A4 as an output set to False
- D9 as an input
While contacting A4 and D9 is detected right away, when I break the contact, there is 2 sec delay before the input reads True again...
Why is that ?
here is the code used :
import board
import digitalio
import time
def set_pin(var_name, pin_name, out=True):
globals()[var_name] = pin = digitalio.DigitalInOut(getattr(board, pin_name))
pin.direction = getattr(digitalio.Direction, "OUTPUT" if out else "INPUT")
set_pin("key_out", "A4")
set_pin("key_in", "D9", out=False)
set_pin("led", "BLUE_LED")
key_out.value = False #self-note :: PullUp logic : offer ground to input
#signal the code is executed
for x in range(2):
led.value = True
time.sleep(1)
led.value = False
time.sleep(1)
# visually confirm key_in.value is True
for x in range(2 if key_in.value else 10):
led.value = True
time.sleep(0.1)
led.value = False
time.sleep(0.1)
time.sleep(3)
def test():
old_input = key_in.value
while True :
if input != old_input :
if not old_input :
print("key Depressed")
led.value = False
else :
print("key pressed")
led.value = True
old_input = input
test()
