Watchdog on Feather Express M4
baxtertidwell
Post by baxtertidwell »
Apparently, the wdt library is not supported by the SAMD processors. I need a watchdog and came across SleepyDog. I'm not interested in the sleep part, just the watchdog.
I'm not having much luck. No matter what value I use for
int countdownMS = Watchdog.enable(6000);
Serial.print(countdownMS, DEC);
countdownMS always comes back as something else. Here are some random values:
400 sets to 250
1500 sets to 1000
2200 sets to 2000
2500 sets to 2000
6000 sets to 4000
16000 sets to 16000 but 15000 sets to 8000.
But the biggest problem is, when it is not reset in time, there's an exception that seems to have something to do with Serial. I would have expected a watchdog timeout to restart the code.
Are my assumptions wrong? Or is there a better tool I should be using for a watchdog timer?
Here's the error FWIW:
Exception in thread rx:
  File "C:\Users\Baxter\.platformio\python3\lib\threading.py", line 926, in _bootstrap_inner
    self.run()
  File "C:\Users\Baxter\.platformio\python3\lib\threading.py", line 870, in run
    self._target(*self._args, **self._kwargs)
  File "c:\users\Baxter\.platformio\penv\lib\site-packages\serial\tools\miniterm.py", line 445, in reader
    data = self.serial.read(self.serial.in_waiting or 1)
  File "c:\users\Baxter\.platformio\penv\lib\site-packages\serial\serialwin32.py", line 257, in in_waiting
    raise SerialException("ClearCommError failed ({!r})".format(ctypes.WinError()))
serial.serialutil.SerialException: ClearCommError failed (PermissionError(13, 'The device does not recognize the command.', None, 22))
baxtertidwell
Re: Watchdog on Feather Express M4
Thanks, User_UM...
That is a nice, simple approach that does only one thing. And works on the SAMD51.
User_UMjT7KxnxP8YN8
Post by User_UMjT7KxnxP8YN8 »
I grew up during the Dragnet "Just the facts, ma'am" era.
akki0075
Post by akki0075 »
Does anyone know what is the minimum power requirement to trigger the Watchdog.sleep(timeout)?? Is it 3.1V, 3.2V or 3.3?
Akshay
Return to “Itsy Bitsy Boards”
