PC doesn't recognize Itsy Bitsy
by topper2k on Fri Apr 16, 2021 11:30 pm
I’ve got a project (an arcade lightgun) built with a ItsyBitsy 32U4 5v 16mhz board. To initially install my project, I followed all the steps to add the board and get it setup with the IDE. (https://learn.adafruit.com/introducting ... -ide-setup).
The project has been working fine for a couple weeks. Today I plugged it in to upload a code update and I can’t seem to connect to the board.
I get the normal beep boop when I plug the USB cable in. But I don’t see the device in Device Manager.
In the Arduino IDE, I can see I have the correct board selected, but the com port selection is grayed out.
Looking at the board I’ve got a single red blinking LED.
Here's what I've already tried:
Rebooted the PC
Uninstalled and reinstalled Arduino IDE
Reinstalled board list
Manually installed Adafruit device drivers
Any idea what could be wrong?
topper2k
Re: PC doesn't recognize Itsy Bitsy
by topper2k on Sat Apr 17, 2021 9:39 am
I've tried this on three different PCs now with the same results. Two of the PCs had previously been used to upload sketches to this ItsyBitsy board. The third was a fresh install of the Arduino IDE, etc. I'm stumped.
topper2k
by topper2k on Sat Apr 17, 2021 9:57 am
I think I've solved this.
I activated the bootloader by double tapping the reset button. Then I initiated an upload of the "bare minimum" example sketch. And double tapped the reset button again.
This successfully uploaded the minimum sketch. I was then able to upload other sketches as well.
topper2k
