ADC readings off on Itsy Bitsy M4
Re: ADC readings off on Itsy Bitsy M4
by Bekar_T on Thu May 06, 2021 3:54 am
Nope, actually, cancel that.
2% is an expression of the sum of ADC and DAC errors. ADC alone has a very consistent 5% error when readings are taken in reference with the external source.
I'm assuming I'll find a DAC error to be about 3% and "in an opposite direction", resulting in 2% net error when they are tied with a jumper wire.
If that can't be addressed at least to some extent, I think it should at least mentioned somewhere because when a description says:
Dual 1 MSPS 12 bit true analog DAC
Dual 1 MSPS 12 bit ADC
A beginner like myself (who, as we've established, these boards are targeted at) would not assume there could be an unspoken assumption that 5% error in readings is not an odd thing to happen.
Bekar_T
by Bekar_T on Thu May 06, 2021 4:56 am
Wellp, now I'm confused.
DAC output has barely 0.5% error when measured independently.
So main source of error is ADC and it varies A LOT depending on . . . I don't know what.
Does this mean that even if I go through the labors of calibrating and compensating for the error in ADC, it will still need adjusting in every specific circuit configuration?
Bekar_T
