Adafruit 1.14" 240x135 Color TFT Breakout LCD Display
by kscharf on Mon May 10, 2021 12:29 pm
I tried using the Adafruit 1.14" 240x135 Color TFT Breakout LCD Display with the itsy bitsy M0 board.
I followed the wiring in the tutorial (changed the RST to -1 and wired to the itsy RST pin, changed the DC to pin 7 (no pin 8 on the itsy), wired MOSI and SCK to the itsy pins of the same names). I made the changes to the graphicstest.ino file in the tutorial. I get nothing on the LCD display. Not even seeing light leakage from the backlight. The LCD LIT, MISO, and SDCD pins are not hooked up. Also tried connecting the VIN to both the USB and the 3v pins on the itysy. (IE: using the 3v regulator on the display or on the itsy).
I bought two of these displays when they first came out for future projects, just got around to testing one of them today. Is it possible I have a bad display? The itsy is good, it's running a sketch with the DSP310 right now (wanted to use the display to show trends in barometer pressure).
kscharf
Re: Adafruit 1.14" 240x135 Color TFT Breakout LCD Display
by adafruit_support_carter on Mon May 10, 2021 12:40 pm
Just to be clear - you've only tried one of them so far?
Can you post a photo of your setup showing how everything is wired together.
by kscharf on Mon May 10, 2021 1:18 pm
Yes, only opened up one of the packages.
kscharf
by adafruit_support_carter on Mon May 10, 2021 1:36 pm
Thanks for the photo. Generally looks OK.
Did that include the changes here?
https://learn.adafruit.com/adafruit-1-1 ... iring-test
for commenting/uncommenting the specific lines used for that display?
by kscharf on Mon May 10, 2021 1:59 pm
Yes, I modded the lines mentioned. Actually, it won't even compile if you don't make some of the changes!
Should the backlight come on if only the power and ground is connected? Looks like the LIT pin is pulled up (need to pull it down to shut OFF the backlight). Even if the LCD is not active SOME light should leak out through the sides, (it isn't).
kscharf
by adafruit_support_carter on Mon May 10, 2021 2:03 pm
Looks like the backlight on that one does not come on. I've setup a Itsy M0 here and it works OK. Can you try with the wiring per the guide? And hook up RST also just to test that it works.
by kscharf on Mon May 10, 2021 4:48 pm
I've already wired it as per the guide, the only difference was using pin 7 instead of 8 for DC (no pin 8 on the itsy). I tried with RST to pin 9, and RST on the itsy.
I've attached the modified ino file.
No change.
OK, in a darkened room I CAN see some of the backlight leaking out from the edge of the display. It's MUCH fainter than I thought it would be, other TFT displays I've used in the past had more backlight leakage. So it's not the backlight, the LCD isn't working.
Maybe later I'll open up the other display, attach the pins and try it.
graphicstgraphicstest.ino.ino
(10.47 KiB) Downloaded 3 times
kscharf
by adafruit_support_carter on Mon May 10, 2021 5:35 pm
Yep, I did same - used 7 instead of 8 for TFT_DC. Should just work.
Here's the full modifeid sketch.
  This is a library for several Adafruit displays based on ST77* drivers.
  Works with the Adafruit 1.8" TFT Breakout w/SD card
    ----> http://www.adafruit.com/products/358
  The 1.8" TFT shield
    ----> https://www.adafruit.com/product/802
  The 1.44" TFT breakout
    ----> https://www.adafruit.com/product/2088
  The 1.14" TFT breakout
  ----> https://www.adafruit.com/product/4383
  The 1.3" TFT breakout
  ----> https://www.adafruit.com/product/4313
  The 1.54" TFT breakout
    ----> https://www.adafruit.com/product/3787
  The 2.0" TFT breakout
    ----> https://www.adafruit.com/product/4311
  as well as Adafruit raw 1.8" TFT display
    ----> http://www.adafruit.com/products/618
  Check out the links above for our tutorials and wiring diagrams.
  These displays use SPI to communicate, 4 or 5 pins are required to
  interface (RST is optional).
  products from Adafruit!
  MIT license, all text above must be included in any redistribution
#include <Adafruit_GFX.h>    // Core graphics library
#include <Adafruit_ST7735.h> // Hardware-specific library for ST7735
#include <Adafruit_ST7789.h> // Hardware-specific library for ST7789
#include <SPI.h>
#if defined(ARDUINO_FEATHER_ESP32) // Feather Huzzah32
  #define TFT_CS         14
  #define TFT_RST        15
  #define TFT_DC         32
#elif defined(ESP8266)
  #define TFT_CS         4
  #define TFT_RST        16
  #define TFT_DC         5
#else
  // For the breakout board, you can use any 2 or 3 pins.
  // These pins will also work for the 1.8" TFT shield.
  #define TFT_CS        10
  #define TFT_RST        9 // Or set to -1 and connect to Arduino RESET pin
  #define TFT_DC         7
#endif
// OPTION 1 (recommended) is to use the HARDWARE SPI pins, which are unique
// to each board and not reassignable. For Arduino Uno: MOSI = pin 11 and
// SCLK = pin 13. This is the fastest mode of operation and is required if
// using the breakout board's microSD card.
// For 1.44" and 1.8" TFT with ST7735 use:
//Adafruit_ST7735 tft = Adafruit_ST7735(TFT_CS, TFT_DC, TFT_RST);
// For 1.14", 1.3", 1.54", and 2.0" TFT with ST7789:
Adafruit_ST7789 tft = Adafruit_ST7789(TFT_CS, TFT_DC, TFT_RST);
// OPTION 2 lets you interface the display using ANY TWO or THREE PINS,
// tradeoff being that performance is not as fast as hardware SPI above.
//#define TFT_MOSI 11  // Data out
//#define TFT_SCLK 13  // Clock out
// For ST7735-based displays, we will use this call
//Adafruit_ST7735 tft = Adafruit_ST7735(TFT_CS, TFT_DC, TFT_MOSI, TFT_SCLK, TFT_RST);
// OR for the ST7789-based displays, we will use this call
//Adafruit_ST7789 tft = Adafruit_ST7789(TFT_CS, TFT_DC, TFT_MOSI, TFT_SCLK, TFT_RST);
float p = 3.1415926;
void setup(void) {
  Serial.print(F("Hello! ST77xx TFT Test"));
  // Use this initializer if using a 1.8" TFT screen:
  //tft.initR(INITR_BLACKTAB);      // Init ST7735S chip, black tab
  // OR use this initializer if using a 1.8" TFT screen with offset such as WaveShare:
  // tft.initR(INITR_GREENTAB);      // Init ST7735S chip, green tab
  // OR use this initializer (uncomment) if using a 1.44" TFT:
  //tft.initR(INITR_144GREENTAB); // Init ST7735R chip, green tab
  // OR use this initializer (uncomment) if using a 0.96" 160x80 TFT:
  //tft.initR(INITR_MINI160x80);  // Init ST7735S mini display
  // OR use this initializer (uncomment) if using a 1.3" or 1.54" 240x240 TFT:
  //tft.init(240, 240);           // Init ST7789 240x240
  // OR use this initializer (uncomment) if using a 2.0" 320x240 TFT:
  //tft.init(240, 320);           // Init ST7789 320x240
  // OR use this initializer (uncomment) if using a 1.14" 240x135 TFT:
  tft.init(135, 240);           // Init ST7789 240x135
  // SPI speed defaults to SPI_DEFAULT_FREQ defined in the library, you can override it here
  // Note that speed allowable depends on chip and quality of wiring, if you go too fast, you
  // may end up with a black screen some times, or all the time.
  //tft.setSPISpeed(40000000);
  Serial.println(F("Initialized"));
  uint16_t time = millis();
  tft.fillScreen(ST77XX_BLACK);
  time = millis() - time;
  Serial.println(time, DEC);
  delay(500);
  // large block of text
  testdrawtext("Lorem ipsum dolor sit amet, consectetur adipiscing elit. Curabitur adipiscing ante sed nibh tincidunt feugiat. Maecenas enim massa, fringilla sed malesuada et, malesuada sit amet turpis. Sed porttitor neque ut ante pretium vitae malesuada nunc bibendum. Nullam aliquet ultrices massa eu hendrerit. Ut sed nisi lorem. In vestibulum purus a tortor imperdiet posuere. ", ST77XX_WHITE);
  delay(1000);
  // tft print function!
  tftPrintTest();
  delay(4000);
  // a single pixel
  tft.drawPixel(tft.width()/2, tft.height()/2, ST77XX_GREEN);
  delay(500);
  // line draw test
  testlines(ST77XX_YELLOW);
  delay(500);
  // optimized lines
  testfastlines(ST77XX_RED, ST77XX_BLUE);
  delay(500);
  testdrawrects(ST77XX_GREEN);
  delay(500);
  testfillrects(ST77XX_YELLOW, ST77XX_MAGENTA);
  delay(500);
  testfillcircles(10, ST77XX_BLUE);
  testdrawcircles(10, ST77XX_WHITE);
  delay(500);
  testroundrects();
  delay(500);
  testtriangles();
  delay(500);
  mediabuttons();
  delay(500);
  Serial.println("done");
  delay(1000);
  tft.invertDisplay(true);
  delay(500);
  tft.invertDisplay(false);
  delay(500);
void testlines(uint16_t color) {
  for (int16_t x=0; x < tft.width(); x+=6) {
    tft.drawLine(0, 0, x, tft.height()-1, color);
    delay(0);
  for (int16_t y=0; y < tft.height(); y+=6) {
    tft.drawLine(0, 0, tft.width()-1, y, color);
    delay(0);
    tft.drawLine(tft.width()-1, 0, x, tft.height()-1, color);
    delay(0);
    tft.drawLine(tft.width()-1, 0, 0, y, color);
    delay(0);
    tft.drawLine(0, tft.height()-1, x, 0, color);
    delay(0);
    tft.drawLine(0, tft.height()-1, tft.width()-1, y, color);
    delay(0);
    tft.drawLine(tft.width()-1, tft.height()-1, x, 0, color);
    delay(0);
    tft.drawLine(tft.width()-1, tft.height()-1, 0, y, color);
    delay(0);
void testdrawtext(char *text, uint16_t color) {
  tft.setCursor(0, 0);
  tft.setTextColor(color);
  tft.setTextWrap(true);
  tft.print(text);
void testfastlines(uint16_t color1, uint16_t color2) {
  for (int16_t y=0; y < tft.height(); y+=5) {
    tft.drawFastHLine(0, y, tft.width(), color1);
  for (int16_t x=0; x < tft.width(); x+=5) {
    tft.drawFastVLine(x, 0, tft.height(), color2);
void testdrawrects(uint16_t color) {
    tft.drawRect(tft.width()/2 -x/2, tft.height()/2 -x/2 , x, x, color);
void testfillrects(uint16_t color1, uint16_t color2) {
  for (int16_t x=tft.width()-1; x > 6; x-=6) {
    tft.fillRect(tft.width()/2 -x/2, tft.height()/2 -x/2 , x, x, color1);
    tft.drawRect(tft.width()/2 -x/2, tft.height()/2 -x/2 , x, x, color2);
void testfillcircles(uint8_t radius, uint16_t color) {
  for (int16_t x=radius; x < tft.width(); x+=radius*2) {
    for (int16_t y=radius; y < tft.height(); y+=radius*2) {
      tft.fillCircle(x, y, radius, color);
void testdrawcircles(uint8_t radius, uint16_t color) {
  for (int16_t x=0; x < tft.width()+radius; x+=radius*2) {
    for (int16_t y=0; y < tft.height()+radius; y+=radius*2) {
      tft.drawCircle(x, y, radius, color);
void testtriangles() {
  uint16_t color = 0xF800;
  int t;
  int w = tft.width()/2;
  int x = tft.height()-1;
  int y = 0;
  int z = tft.width();
  for(t = 0 ; t <= 15; t++) {
    tft.drawTriangle(w, y, y, x, z, x, color);
    x-=4;
    y+=4;
    z-=4;
    color+=100;
void testroundrects() {
  uint16_t color = 100;
  int i;
  int t;
  for(t = 0 ; t <= 4; t+=1) {
    int x = 0;
    int y = 0;
    int w = tft.width()-2;
    int h = tft.height()-2;
    for(i = 0 ; i <= 16; i+=1) {
      tft.drawRoundRect(x, y, w, h, 5, color);
      x+=2;
      y+=3;
      w-=4;
      h-=6;
      color+=1100;
    color+=100;
void tftPrintTest() {
  tft.setTextWrap(false);
  tft.setCursor(0, 30);
  tft.setTextColor(ST77XX_RED);
  tft.setTextSize(1);
  tft.println("Hello World!");
  tft.setTextColor(ST77XX_YELLOW);
  tft.setTextSize(2);
  tft.setTextColor(ST77XX_GREEN);
  tft.setTextSize(3);
  tft.setTextColor(ST77XX_BLUE);
  tft.setTextSize(4);
  tft.print(1234.567);
  delay(1500);
  tft.setTextColor(ST77XX_WHITE);
  tft.setTextSize(0);
  tft.setTextSize(1);
  tft.print(p, 6);
  tft.println(" Want pi?");
  tft.println(" ");
  tft.print(8675309, HEX); // print 8,675,309 out in HEX!
  tft.println(" Print HEX!");
  tft.println(" ");
  tft.println("Sketch has been");
  tft.println("running for: ");
  tft.setTextColor(ST77XX_MAGENTA);
  tft.print(millis() / 1000);
  tft.print(" seconds.");
void mediabuttons() {
  // play
  tft.fillRoundRect(25, 10, 78, 60, 8, ST77XX_WHITE);
  tft.fillTriangle(42, 20, 42, 60, 90, 40, ST77XX_RED);
  delay(500);
  // pause
  tft.fillRoundRect(25, 90, 78, 60, 8, ST77XX_WHITE);
  tft.fillRoundRect(39, 98, 20, 45, 5, ST77XX_GREEN);
  tft.fillRoundRect(69, 98, 20, 45, 5, ST77XX_GREEN);
  delay(500);
  // play color
  tft.fillTriangle(42, 20, 42, 60, 90, 40, ST77XX_BLUE);
  delay(50);
  // pause color
  tft.fillRoundRect(39, 98, 20, 45, 5, ST77XX_RED);
  tft.fillRoundRect(69, 98, 20, 45, 5, ST77XX_RED);
  // play color
  tft.fillTriangle(42, 20, 42, 60, 90, 40, ST77XX_GREEN);
Try the second display and see what happens. Another thing to try might be to more directly connect the TFT and Itsy. Avoid using the power rails for now.
by kscharf on Mon May 10, 2021 5:56 pm
I copied your code and ran that. Added wires direct from VIN to 3V and GND to G in parallel with the rails.
Still no joy. I'll try the other display tomorrow, getting near diner time now......
Can't believe I might have zapped the display (ESD) while soldering, have a grounded solder station.
But, I'll be double sure and look for my wrist strap...... (wear that on my ankle, so it doesn't get in the way :-) ) when I solder the pins on the second one.....
Was thinking of using a 16x2 display on the I2C backpack. Would use the trinket M0 then as fewer IO lines required, but I'd rather use a graphics display to show trends as barometer rises and falls.
kscharf
