Matrix Portal M4 can't find MATRIXBOOT
by jsnebben on Fri May 21, 2021 4:23 pm
I'm following the matrix portal M4 setup instructions and can't get the MATRIXBOOT drive to appear. I've tested my usb c cable with another device and that worked for data connection. When I try doubleclicking the reset button the neopixel doesn't turn on at all instead of turning red or green like the Install CircuitPython step mentions. Any idea what else I could be missing?
jsnebben
Re: Matrix Portal M4 can't find MATRIXBOOT
by dastels on Fri May 21, 2021 5:53 pm
Do you see the CIRCUITPY drive?
dastels
by jsnebben on Sat May 22, 2021 11:59 am
No I don't. There's no new drive that shows up
jsnebben
by dastels on Sat May 22, 2021 3:39 pm
Do you see any activity on the NeoPixel or LED at all?
Does a serial port show up for it?
Can you upload a sketch (e.g. blink) from Arduino?
dastels
by jsnebben on Sat May 22, 2021 4:41 pm
I get no activity at all.
No serial port shows up.
I'm not able to upload a sketch from arduino.
jsnebben
by dastels on Sat May 22, 2021 4:59 pm
Is this with the MatrixPortal on it's own with nothing connected to it?
dastels
by jsnebben on Sat May 22, 2021 5:24 pm
I've tried it both connected to and disconnected from a 64x32 rgb led matrix and had the same result
jsnebben
by dastels on Sat May 22, 2021 5:40 pm
OK. It sounds dead.
Please email support@adafruit.com with a link to this thread, your order number, and request the replacement of one MatrixPortal M4.
dastels
