I connect battery to ItsyBitsy nRF52840 but not working.
by LiuToki on Sat Jun 05, 2021 11:21 pm
Hello.
I use Adafruit ItsyBitsy nRF52840 Express (https://learn.adafruit.com/adafruit-its ... s?view=all)
I already programmed to this board and checked its works with USB connection.
The program is like a keyboard with a bluetooth connection. And the LED on the board lights up when the power is turned on.
And then I decided to use the battery and plugged in the Li battery to BAT pin and GND pin.
But, not working.
I connect the battery + to BAT pin and - to GND pin.
When I measure the voltage between the BAT pin and the GND pin, I have confirmed that it is about 4V.
Is there anything else wrong?
Also, please tell me if you need any other information to resolve.
Thank you,
LiuToki
Re: I connect battery to ItsyBitsy nRF52840 but not working.
by dastels on Sun Jun 06, 2021 8:50 am
Does it work with both USB and a battery connected?
Can you measure the voltage on these pins: 3v, EN, Vhi. Ideally with just USB, just a battery, and both connected.
dastels
by LiuToki on Wed Jun 09, 2021 8:10 pm
Hi, Dave.
Thank you for your reply.
I Check the voltage following pins with the 3 ways.
- Only USB
3V: 3.26[V]
EN: 4.88[V]
Vhi: 4.94[V]
- Only BAT
3V: 0.00
EN: 0.00
0.00
- Both USB & BAT
3V: 3.26
EN: 4.90
Vhi: 4.95
By the way, When I connected both USB & BAT and measured the voltage of between BAT and GND, it was 7.28[V].
Ray.
LiuToki
by dastels on Wed Jun 09, 2021 10:26 pm
What are you using for a battery?
dastels
by LiuToki on Thu Jun 10, 2021 9:47 pm
I use Lithium rechargeable battery.
Spec is 3.7V 900mAh 1.8A.
I charged with the charging circuit before using it.
If I can use DC 5V(from using AC/DC) instead of battery to BAT pin, I'll try to check whether the battery is broken.
Ray.
LiuToki
by LiuToki on Wed Jun 30, 2021 10:52 pm
Hello.
I check AP2112 Datasheet and that VIN max voltage is 6[V].
So I input 5[V] to BAT pin(from using AC/DC).
I confirmed that there is a voltage of 5V between BAT and GND.
But following pins are 0[V].
3V: 0.00
EN: 0.00
Vhi: 0.00
Is this a problem with the main unit?
Is there anything else I should check?
Ray.
LiuToki
by LiuToki on Sat Jul 03, 2021 2:02 am
Hello.
I requested a friend who has the same product to apply a voltage of 5 [V] to the BAT pin to see if it works.
Then, it works(Look at the following image).
So, I think my device is maybe broken.
So sad...
What should I do ?
Do I have to buy a new one again?
Ray.
my friend device.
LiuToki
by LiuToki on Sat Jul 03, 2021 2:26 am
Hello.
I found why my board does not work.
Look at the picture!
WTF, the VBAT diode is not mounted!
Can you to send me a new board?
I bought this board DigiKey Electronics through marutsu online(https://www.marutsu.co.jp/).
Thanks.
LiuToki
