I recently got some new LEDMatrix boards described as HUB08 and have a rather odd problem.
The 64 x 16 display will work ( sort of ) when connected to the Itsy Bitsy M0, with the power to the display board OFF there is a feint display. The display seems to use the voltage from the data lines. If I turn power to the display board ON the display goes blank and when I turn the power OFF I get the feint display shows again. The parasitic voltage is about 1.67V
The IB M0 and display are fed from the same source - LiPo battery @ 5.1V and have a common ground.
To get the display to this stage I had to tweak ( i.e. trial and error adjustments) the 'Scan One Row' by adding a delay to the Clock signal.
The same hardware set up, with different display boards, works as expected. I have used other boards with 16 8x8 matrix modules and a 64 x 16 SMD LED board. These boards have been OK with the IB M0 signal levels - I have not tried a level convertor on the new board.
I would welcome advice on what to try next?
Ted Finch
The Scan One Row called by an Interval Timer ISR:
ScanOneRow - written for Arduino MO processor on Adafruit board
Bit bang data line, clock line and latch line
void LEDMatrix::scanOneRow()
//process one row - shift out bits from one row in buffer
static uint8_t row = 0;//initial value of 0
//if row is 0 do buffer swap if double buffering required
int rowstart ;
uint8_t pixelsbyte;
uint16_t clk_time = 4; // pause on data clock high and low in usecs, 4 gives best result on parasitic voltage
//set row address
if (!state) { return; }
if (row == 0) {
if(swapflag == true) {
// Switch buffer indices so the alternate buffer is written/read
buffer_being_read = 1 - buffer_being_read;
displaybuff = dbuffers[ buffer_being_read];
writebuff = dbuffers[BUFFER_TO_FILL];
swapflag = false;
digitalWrite_fast(en, HIGH); //disable display - can control with PWM
rowstart = row * 8; //step through rows each has 8 bytes
//send data
for (int8_t rowbyte = 7; rowbyte >= 0; rowbyte--) { //8 bytes from this row IN reverse
pixelsbyte = ( displaybuff[rowstart + rowbyte]) ^ mask ;
for (int8_t bit = 7; bit >=0 ; bit--) { // 8 bits for this byte start at high bit
digitalWrite_fast(clk, LOW);
delayMicroseconds(clk_time); // Delay added
digitalWrite_fast(r1, pixelsbyte & (0x80 >> bit));
digitalWrite_fast(clk, HIGH);//Clock on Rising Edge
}//8 BITS
}//8 BYTES
digitalWrite_fast(lch, LOW);
//zero latchPin and hold low for a while
digitalWrite_fast(a, !bitRead(row, 0x00));
digitalWrite_fast(b, !bitRead(row, 0x01));
digitalWrite_fast(c, !bitRead(row, 0x02));
digitalWrite_fast(d, !bitRead(row, 0x03));
// latch data
digitalWrite_fast(lch, HIGH);
digitalWrite_fast(en, LOW); //enable display
row = (row + 1) & 0x0F; //next row next time round
Similar Code here: https://github.com/jkairys/HUB08/blob/master/HUB08.cpp
