My versions:
Arduino 1.8.13
Adafruit TinyUSB Library 1.4.2 (installed through library manager)
Arduino IDE Settings:
Board: Adafruit ItsyBitsy M0
USB Stack: TinyUSB
Debug: Off
Port: COM16 (Adafruit ItsyBitsy M0)
Steps:
1. Plug in a never-before-used ItsyBity (purchased in January 2021) to USB
2. Choose the hid_gamepad example (all examples have some type of error)
3. Click Verify (or Upload)
4. See errors highlighting line (also attached in image): Adafruit_USBD_HID usb_hid;
hid_gamepad:31:19: error: cannot declare variable 'usb_hid' to be of abstract type 'Adafruit_USBD_HID'
31 | Adafruit_USBD_HID usb_hid;
In file included from C:\Users\Matt\Documents\Arduino\libraries\Adafruit_TinyUSB_Library\src/Adafruit_TinyUSB.h:42,
from C:\Users\Matt\Documents\Arduino\libraries\Adafruit_TinyUSB_Library\examples\HID\hid_gamepad\hid_gamepad.ino:12:
C:\Users\Matt\Documents\Arduino\libraries\Adafruit_TinyUSB_Library\src/arduino/hid/Adafruit_USBD_HID.h:30:7: note: because the following virtual functions are pure within 'Adafruit_USBD_HID':
30 | class Adafruit_USBD_HID : public Adafruit_USBD_Interface {
In file included from C:\Users\Matt\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.6.3\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/Adafruit_TinyUSB_Core.h:35,
from C:\Users\Matt\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.6.3\cores\arduino/Arduino.h:154,
from sketch\hid_gamepad.ino.cpp:1:
C:\Users\Matt\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.6.3\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/Adafruit_USBD_Device.h:38:22: note: 'virtual uint16_t Adafruit_USBD_Interface::getDescriptor(uint8_t, uint8_t*, uint16_t)'
38 | virtual uint16_t getDescriptor(uint8_t itfnum, uint8_t* buf, uint16_t bufsize) = 0;
hid_gamepad:33:1: error: 'hid_gamepad_report_t' does not name a type; did you mean 'hid_keyboard_report_t'?
33 | hid_gamepad_report_t gp; // defined in hid.h from Adafruit_TinyUSB_ArduinoCore
C:\Users\Matt\Documents\Arduino\libraries\Adafruit_TinyUSB_Library\examples\HID\hid_gamepad\hid_gamepad.ino: In function 'void setup()':
hid_gamepad:52:11: error: 'TinyUSBDevice' was not declared in this scope; did you mean 'USBDevice'?
52 | while( !TinyUSBDevice.mounted() ) delay(1);
| USBDevice
C:\Users\Matt\Documents\Arduino\libraries\Adafruit_TinyUSB_Library\examples\HID\hid_gamepad\hid_gamepad.ino: In function 'void loop()':
hid_gamepad:72:3: error: 'gp' was not declared in this scope
72 | gp.x = 0;
exit status 1
