itsybitsy circuitpython measuring time time.clock()
frednikgohar
Post by frednikgohar »
I'm trying to measure time between two events in my Circuit Python app running on an ItsyBitsy Express (prod page: https://www.adafruit.com/product/4481)
I've used the time module in a desktop app before and I know that Circuit Python does have a time module - for example:
import time
time.sleep(1)
will pause execution for 1 sec.
However, time.clock() doesn't seem to be supported. The following code
import time
t = time.clock
x = time.
print(t)
Throws the following error
21:47:46.421 -> soft reboot
21:47:46.421 ->
21:47:46.421 -> Auto-reload is on. Simply save files over USB to run them or enter REPL to disable.
21:47:46.489 -> code.py output:
21:47:46.489 -> Traceback (most recent call last):
21:47:46.489 ->   File "code.py", line 5
21:47:46.489 -> SyntaxError: invalid syntax
21:47:46.489 ->
21:47:46.489 -> Code done running.
21:47:46.489 ->
21:47:46.489 -> Press any key to enter the REPL. Use CTRL-D to reload.
Is time.clock() not supported in CP and/or my particular board?
Either way, I want to measure the time difference from the time an LED lights up till the user pushes a button. How can I go about this? Thanks in advance for helping out a newbie prorammer.
frednikgohar
Re: itsybitsy circuitpython measuring time time.clock()
It appears that one possible solution is to use time.monotonic() which outputs the number of seconds since the board was last powered up. If so, one should be able to call it in both Event1 and Event2, subtract, and get the difference.
I have tested it and it works on ItsyBitsy Express. What is not yet clear is the function's resolution... for example, can it do milliseconds?
Franklin97355
Post by Franklin97355 »
Return to “Itsy Bitsy Boards”
