I'm try to find the C preprocessor symbol defined to identify the ItsyBitsy M4 hardware (using Arduino IDE).
When compiling for the Feather M0 Express, symbol ARDUINO_SAMD_FEATHER_M0_EXPRESS is defined and can be tested.
What would be the equivalent for ItsyBitsy M4? I tried ARDUINO_SAMD_ITSYBITSY_M4 and ARDUINO_SAMD_ITSYBITSY_M4_EXPRESS, ADAFRUIT_SAMD_ITSYBITSY_M4 and ADAFRUIT_SAMD_ITSYBITSY_M4_EXPRESS but none of them seem to be defined...
I detected a _VARIANT_ITSYBITSY_M4 in one of the core files, but it doesn't seem to be defined either.
Thanks for your clarifications!
Alain.
PS: more generally, where can I find this information for other Adafruit boards?
cpp symbol for ItsyBitsy M4
- mikeysklar
Re: cpp symbol for ItsyBitsy M4
This github repo contains boards.txt:
https://github.com/adafruit/ArduinoCore-samd
$ grep -i itsybitsy boards.txt | grep board
adafruit_itsybitsy_m0.build.board=ITSYBITSY_M0
adafruit_itsybitsy_m4.build.board=ITSYBITSY_M4
- AlainB
That was fast... Thanks a lot! :-)
- mikeysklar
You pretty much guess the right name. Just need an underscore.
- AlainB
Mmmh, I'm afraid that's not the symbol I'm looking for,.. I think the symbol should be defined somewhere in a header file I cannot locate, and that it probably is not that easy to guess, after all... :-)
Let's compile this sketch:
I get this when compiling for Feather M0 Express, which is as expected (symbol ARDUINO_SAMD_FEATHER_M0_EXPRESS is defined):
When compiling for ItsyBitsyM4, I get this (the ITSYBITSY_M4 symbol is clearly not defined, so which one is??):
Sorry to inconvenience...
Alain.
#include "Arduino.h"
#ifdef ARDUINO_SAMD_FEATHER_M0_EXPRESS
#error Feather M0 express
#else
#error not Feather M0 express
#endif
#ifdef ITSYBITSY_M4
#error M4
#else
#error not M4
#endif
void setup() {}
void loop() {}
~/Documents/Arduino/cansat-asgard/personal/baudhuin/TestItsyBitsyM4 >arduino-cli compile --fqbn adafruit:samd:adafruit_feather_m0_express
/Users/Alain/Documents/Arduino/cansat-asgard/personal/baudhuin/TestItsyBitsyM4/TestItsyBitsyM4.ino:6:2:
#errror Feather M0 express
/Users/Alain/Documents/Arduino/cansat-asgard/personal/baudhuin/TestItsyBitsyM4/TestItsyBitsyM4.ino:14:2: error: #error not M4
#error not M4
Error during build: exit status 1
~/Documents/Arduino/cansat-asgard/personal/baudhuin/TestItsyBitsyM4 >arduino-cli compile --fqbn adafruit:samd:adafruit_itsybitsy_m4
/Users/Alain/Documents/Arduino/cansat-asgard/personal/baudhuin/TestItsyBitsyM4/TestItsyBitsyM4.ino:8:2: error: #error not Feather M0 express
#error not M4
Alain.
- mikeysklar
my bad....brute force google searching turned this up:
ARDUINO_ITSYBITSY_M4
- AlainB
That's the one!
Your brute force search is definetely better than mine.
Issue closed, thanks!
